How much life left in the engine?
Old May 26, 2005 | 08:14 AM
Mark_Sheehy's Avatar
Mark_Sheehy
Default How much life left in the engine?
I have an 89 convertible with 86k miles, completely stock L98. When I bought it 6 years ago, the oil pressure seemed lower than it should be when fully warmed up (20 psi). Fast forward to now and it drops to 9-11 psi (saw 9 psi for the first time last night) when completely warmed up and sitting a stop light. It is still around 50-55 psi when I start it up cold in the morning, same as it was when I bought it. I use Mobil 1 5w-30, which was in the car when I bought it and I continue to use. It doesn't burn any oil to speak of and runs fine. I am suspecting the bearings are wearing more, increasing the gaps, lowering the oil pressure. I haven't checked the pressure with a manual gauge, but since the cold pressure is the same as it was 6 years ago and only the hot pressure is dropping, the gauge is probably fine. I have heard the adage of 10 psi per 1000 rpm, but 9 psi at idle seems way too low.
Question: How much longer should I expect the engine to last? Is this thing about to drop to zero while driving and grenade the engine?
Old May 26, 2005 | 08:19 AM
Nathan Plemons's Avatar
Nathan Plemons
You're fine. 86k miles is nothing for a small block chevy. You might try running a slightly thicker oil, say 10w30 and see if it makes any difference. In theory it shouldn't make a difference when fully warmed up, but in practice it always seems to make a little difference.
Old May 26, 2005 | 09:04 AM
rick lambert's Avatar
rick lambert
I think I would hook up a mechanical guage to see if there's a malfunction with your guage.The oil pressure you're talking about may be acceptable-but I think it's not right unless at some point something happened to the engine.Could be the sending unit.
Old May 26, 2005 | 09:18 AM
cyclebuyer's Avatar
cyclebuyer
I've been wondering if my guage is right... At cold start it always shows 80. Driving 65 mph, it shows 70-80. The lowest I've seen was 55, that was sitting at a red light in Memphis traffic about 90 degrees outside temp.
Oh yeah...86 model, 115,000 miles.
Old May 26, 2005 | 09:28 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
It all in how the motor has been taken care of.
My car has 144K on it and runs very strong!
Old May 26, 2005 | 09:31 AM
Red Tornado's Avatar
Red Tornado
Mark, previous posts bring up good points......worst case scenario possibility are overly worn rod bearings thats causing low oil pressure (assuming sending unit and gage checks out ok)
Old May 26, 2005 | 09:49 AM
cv67's Avatar
cv67
St. Jude Donor '05
Dont feel bad..Even cold, my pressure is never more than 50 punds or so. That's with a thicker oil. At idle its around 15-20 which is fine. When its hot, it drops down low like yours. Remember, these cars idle very low so your pressure may be also. I wouldn't worry about it. 124k miles here, never smokes. Small block Chevys usually only require 10psi per 1000 rpm. Heck my last motor (fresh) only idled at 15 psi with a Malling hv55 pump. Machinist said
Old May 26, 2005 | 10:09 AM
TA's Avatar
TA
Just keep up with the routine maintenance and you'll be fine. I keep expecting something to let go on my L98 and it just keeps getting stronger, even at 116k....................and I beat the hell out of it
Old May 26, 2005 | 10:17 AM
newbecorvetteguy's Avatar
newbecorvetteguy
First, look up the spec for what's normal. Then check with a mechanical gauge.
With low pressure at idle and no other problems noted, smoke, knocking, ect, the next thing to check would be the pickup tube for the oil pump and the oil pump. If you haven't owned the car since new, you don't know for sure how it was treated. Seen a lot of cars where sludge choked off the pickup tube screen due to infrequent oil changes and the engine never getting up to operating temp. There aren't enough miles on that car for the bearings to be shot. jmo
Old May 26, 2005 | 11:06 AM
vader86's Avatar
vader86
I'm suspecting you either have a bad sender or worn pump. The sending unit is a cheap fix and you need to remove the distributor (and/or the wiper motor) as its screwed into the back of the intake manifold. Its connector also goes bad too, so you may have to cut & splice a new one on.
Otherwise change the pump, Melling M-55A is what I use.
Old May 26, 2005 | 11:08 AM
vader86's Avatar
vader86
Thats a sending unit, anytime you see 80psi on the readout.
Old May 26, 2005 | 12:55 PM
bogus's Avatar
bogus
I would start with the sending unit, too.
GM gauges are notorously inaccurate...
Old May 26, 2005 | 01:58 PM
828790vetteman's Avatar
828790vetteman
1990 Coupe All Original - 54500 miles
Lucas makes an oil additive that they state raises oil pressure. It is a full synthetic and on the bottle it says that it does not void any warranties so I gave it a shot on my last oil change. My oil pressure use to be around 40 or so, and now since the additive went in I run around 60 or so. They suggest you substitute this additive for one quart of oil at change. It is somewhat thick which always worries me but so far engine seems to be happy, (always want the best for the "All American Muscle Machine").
Matt
Old Jun 2, 2005 | 08:20 AM
Mark_Sheehy
I added the synthetic version of Lucas Oil Stabilizer and it did raise it at idle from 9-11 to 14-16 lbs (fully warmed up, in drive, stuck at a traffic light, oil temp @230 degrees). It is higher across the board as well. The service manual says the minimum oil pressure is 6 psi @ 1000 rpm. It is in the 20's at 1000 rpm so I am probably worrying about nothing.
Old Jun 2, 2005 | 10:36 AM
vader86's Avatar
vader86
No, go ahead and replace that sending unit.
Old Jun 2, 2005 | 10:47 AM
wake's Avatar
wake
First thing I did on my 88 IROC when I noticed the oil pressure wasn't what it used to be... It was a cheap $15 sender and when I changed it, the oil pressure went back up to the normal 40 psi cold and I think 25-30 psi hot...
The car had 136K miles on it when I sold it and I ran a carfax on it a few years back just to see what became of the car... The carfax showed it failed it's first smog check at 18xK miles...
I miss that old car... Probably the most reliable car I've ever owned...
To How much life left in the engine?
