hotcam installation
Old May 26, 2005 | 09:45 AM
1996man's Avatar
1996man
Default hotcam installation
i know a lot of ppl here have done this so this should be an easy question. i was working on my car yesterday and was looking things over for when i do my camswap down the road and cant help but wonder if you have to pull the engine to do the cam swap because if you pull the radiator and everything to be able to get everything off to take the timing cover off it looks like if you try and pull the cam out you will hit that cross member. how can u guys jack the engine up that much to tilt it with the tranny still attached? what is the exact proceedure? anyone have any pics? i know theres a lot of you out there that know exactly what to do. please help fill me in
Old May 26, 2005 | 09:49 AM
STL94LT1's Avatar
STL94LT1
The engine has to be lifted just an inch or so to clear the crossmember, and you can leave the trans inact.
I'm getting ready to do my second cam swap this weekend.
Old May 26, 2005 | 09:57 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
It's not hard at all.
Get under your car and look, Under the motor mounts (In the frame) there are 2 bolts. One on each side which hold the motor mounts in place.
There was enough thread on both of my bolts that I loosened them to the ends of the bolt, (I didn't take the nut off cause I didn't want it to misalign itself)
Put my floor jack (with a block of wood) under the bellhousing (my oil pan was off) and lifted slowly.
The motor started rising up the inch I needed to get the cam out.
Once I put the new cam in I let the motor down and retightend both of these bolts. This was the only part of the cam swap I needed the motor jacked up for. (Well it also helps when you re-install the oil pan if you take it completly off)
Old May 26, 2005 | 11:42 AM
1996man's Avatar
1996man
is there a write up on it with pics? i was a member of the GS registry and i was told they had a ncie write up but my membership ran out. can anyone post this one?
Old May 26, 2005 | 11:51 AM
STL94LT1's Avatar
STL94LT1
http://www.hashmarks.com/techtips/hot_cam.htm
Old May 26, 2005 | 12:01 PM
Gary04Z06's Avatar
Gary04Z06
Hopefully you will be doing your third soon. I might be getting ready to switch out the cam in the next few months.
Old May 26, 2005 | 12:04 PM
STL94LT1's Avatar
STL94LT1
Hopefully work will slow down by then. Right now I hardly have time to keep up on my own projects.
Old May 26, 2005 | 01:50 PM
96GS#007's Avatar
96GS#007
Yank the engine, freshen things up, and do the heads too!
Old May 26, 2005 | 01:52 PM
96dblblack's Avatar
96dblblack
This is the procedure that I used and it worked well for me. Good luck
Old May 26, 2005 | 05:07 PM
1996man's Avatar
1996man
that link is exactly what i needed. thanks a lot you guys!
Old May 26, 2005 | 07:48 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
What an excellent article that is!!!!!!!!!
To hotcam installation
