Not Starting
Old May 26, 2005 | 03:03 PM
89vettefromhell's Avatar
89vettefromhell
Default Not Starting
Ok well i started my car today and it ran fine... started it a second time.. No problems... When i went to start it the 3rd time... it stuttered and then stayed fine... till i tried to move... which case it sputterted down to 300 RPM and then stalled.... when this happened i tried to give it gas.. but the accelerator petal had no effect... wouldnt rev or anything.... ANY IDEAS????
Old May 30, 2005 | 02:58 AM
89vettefromhell
any help at all would be appreciated!
Old May 30, 2005 | 03:10 AM
bogus's Avatar
bogus
hm... what is your fuel pressure? I am thinking fuel pump.
Old May 30, 2005 | 10:03 AM
tigmaned's Avatar
tigmaned
changed your fuel filter lately? check fuel pressure at the fuel rail, a manual will tell what psi our vettes need.
Old May 30, 2005 | 10:10 AM
Pete K's Avatar
Pete K
Sounds like a fuel pump possibly. Check the fuse, connection at the relay and positively buy or borrow a fuel pressure guage. This will confirm it.
Old May 30, 2005 | 10:11 AM
8388's Avatar
8388
St. Jude Donor '14
could be the fuel pump relay too. Can you hear the fuel pump ?
I'd check for spark too. If there's no signs of spark, check the ignition module.
Old Jun 5, 2005 | 05:27 PM
89vettefromhell
nope cant hear the pump. i bought a new pump and am in the process of getting it put in... hoping this will work
Old Jun 6, 2005 | 12:27 AM
kopbet89c4's Avatar
kopbet89c4
When this happened to me, it turned out to be the MAF sensor. As soon as I replaced it with a Microtech MAF sensor, I had slightly less problems and less code 33s. Maybe you also would have vacuum leaks in the intake, or bad/leaky injectors. Maybe also a bad FPR, clogged injectors, or fuel lines. I'd check the fuel pump also. Does or did it ever whine when you were less than 1/4th a tank? Good luck, 89 is usually a hellish year in terms of start ups. Good luck.
To Not Starting
