Here is a dumb question
Old May 26, 2005 | 03:29 PM
USAFPILOT's Avatar
USAFPILOT
Default Here is a dumb question
Does a stock LT4 have the LT4 "hotcam"?
Old May 26, 2005 | 03:35 PM
Hutch's Avatar
Hutch
No, the stock LT4 cam is not the Hot Cam. Here are some specs:
1996 LT1 cam:
205/207 duration, 117 LSA
LT4 cam:
203/210 duration, 115 LSA
Hot Cam:
218/228 duration, 112 LSA
Old May 26, 2005 | 03:39 PM
USAFPILOT's Avatar
USAFPILOT
So would the Hotcam give the engine better performance, without upgrading the rest of the valve train, or do you have to do that?
Old May 26, 2005 | 04:03 PM
Hutch's Avatar
Hutch
Going into an LT4, you can install the Hot Cam alone without upgrading the rest of the valvetrain. But since you have to tear it down anyway, its a good opportunity to install new rockers, springs, head work, etc. And if you have a lot of miles on the car, you should install a new set of matched springs anyway.
Old May 26, 2005 | 08:09 PM
USAFPILOT's Avatar
USAFPILOT
I have about 100K on the car...is that all?
Old May 27, 2005 | 07:06 AM
Hutch's Avatar
Hutch
With 100K miles, I would definitely freshen up the heads before installing a new cam. Would be money well spent.
Old May 29, 2005 | 12:27 PM
USAFPILOT's Avatar
USAFPILOT
What about piston rings and parts in the block? When do those need to be looked at?
Old May 29, 2005 | 01:32 PM
tjwong's Avatar
tjwong
At 100k and depending on how well the car was maintained. I would suspect that it wouldn't be too long before having to freshen up rings, and or pistons as well, and bearings. I have one customer in an older 93 LT1 F body still pounding on his LT1 going 12.6's with a Hot Cam and home ported head combo. He has 155k+ on his car now. It smokes on start ups and I suspect compression is getting down as I can literally turn the engine over by just using my hands. Its either low compression or things are polished up inside the engine so well over the miles that the coefficient of friction is very low
To Here is a dumb question
