Are these correct?
1 -- block is a 1 piece;
2 -- Cyl. heads are 58cc;
3 -- Top compression that will work for the HEI ignition = 10:1;
4 -- Do I want an internally or externally balanced crank? (a guy I talked with at Scat said I should only go with an externally balanced crank).
Thanks for the help on this!
1 --Unless you refer to the main caps as separate items, yes.
2 --Some are. Most aren't.
3 --No!
4 --It depends on your wants, needs, and budget. Internally balanced is generally preferable, but more expensive.
I would suggest some books. Something along the lines of how to build your first engine. Also, subscribe to some magazines and pay close attention the the engine, how to, articles.
RACE ON!!!
