Moog Ball Joint Install ?
Old May 27, 2005 | 09:28 PM
mothersworry's Avatar
mothersworry
Default Moog Ball Joint Install ?
I am installing Moog ball joints in my upper a arm on my 92. Does the boot go through the bottom plate or does it just rest up against the plate.
Does the plate go this way with the rim up
Or This way with the rim down
Old May 28, 2005 | 09:48 AM
mothersworry
ttt
Old May 28, 2005 | 02:10 PM
mothersworry
Someone has got to know this answer
Old May 28, 2005 | 03:03 PM
CFI-EFI's Avatar
CFI-EFI
The boot retainer plate installs above the upper control arm with the boot retaining "rim" facing down, as in your second pic. If the "rim" were to face the other way, it wouldn't be able to retain the bead of the boot.
RACE ON!!!
Old May 28, 2005 | 05:53 PM
mothersworry
Does the boot go through the rim or does it just rest against the rim?
Old May 28, 2005 | 08:04 PM
CFI-EFI's Avatar
CFI-EFI
The boot installs through the retaining ring. The "rim" that you refers to is what the square bead of the boot sits into. The bead of the boot is captured between the bottom of the ball joint and the rim of the retainer plate.
RACE ON!!!
Old May 28, 2005 | 09:28 PM
mothersworry
CFI-EFI thanks for all the help. It seems you are the only one on the forum who knows how this works. Guess that makes two. I have added two pictures for your verification of the correct position of the boot. Please let me know if these are correct.
Old May 29, 2005 | 10:48 AM
CFI-EFI's Avatar
CFI-EFI
BINGO!
Then the retainer plate with the boot installed, as pictured, goes between the ball joint and the top of the upper control arm.
RACE ON!!!
Old Jun 24, 2024 | 02:12 PM
pugsutawney's Avatar
pugsutawney
6th Gear
I know this is an old thread but I am currently replacing ball joints on my ‘95 corvette. The retaining plate doesn’t fit over the ball joint assembly and just ends up bending when I try to tighten it down. Anyone know how to get it on.
Old Jun 25, 2024 | 01:09 AM
pugsutawney
6th Gear
Anyone
Old Jun 25, 2024 | 01:29 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Originally Posted by pugsutawney
Anyone
Since this thread is nineteen years old you may have better starting a new thread with your question.
To Moog Ball Joint Install ?
