Drags
Old May 28, 2005 | 09:22 PM
fredk's Avatar
fredk
Default Drags
Well it finally stopped raining up here in Canda and I got to take my 93 auto trans to the track. The first one was my best a 14 flat, I didn't think this was to bad for 2.59 gears. Speed is addictive I think I need a fall project of heads and a cam. We had to quit early as my son's Probe blew a cv. I got my best times leaving the trans in auto.
Old May 29, 2005 | 08:09 PM
pipe's Avatar
pipe
Do it once and it hooks ya. The heads and cam are a good idea it will really make your ride run. The 2.59 gears is what kills it. Maybe go to a 3.07 if ya don't mind givin up some gas mileage. You might want to put on a set of headers and a good set of mufflers then HANG ON GOOD LUCK ON YOUR PROJECT
Old May 29, 2005 | 08:22 PM
Fubar569's Avatar
Fubar569
the gears do blow, but not as much as you expect. my friends 94 auto ran mid/low 13's with stock 2.59's. I suggest long tubes and a full exhaust to get you started, follow up with the heads & cam...however if you yank the heads, a stroker is not that far away! we're taking a few more bolts and a couple of weeks at the machine shop (if your shop is slow)...you are only limited by your cashflow...several built 383's have made damn good numbers and usually pickup some mileage if built properly!
Old May 30, 2005 | 06:18 PM
pipe's Avatar
pipe
Actually my 2.59s were quicker than the 3.07s cause now it sits and spins at the line. My MPH went up quite a bit though
To Drags
