Where do I get an input from my DELTEQ to let my MSD tach light work. I used the MSD box, but when my Delteq gets here, the MSD wont stay on and the MSD is where I had my input for the tach light.
Mines a 93 LT1, and tach filter is already bypassed.
The tach out from the computer will work. I don't remeber what pinout it is off the top of my head.
If you had a '96 (and maybe a 95, but I'm not sure about the '95) the tach output is directly from the ECM.
Since you have a '93, the Tach output from the Delteq is pin D of connector B on the Delteq box.
Go to this site and look at figure 9 on page 15:
Thanks, I think it will work. Also, the white wires going to the tach filter are currently cut, do I need to resoder them, as they were cut for the MSD ignition to allow the tach to work properly.
I know the DELTEQ requires the tach filter to be bypassed, which means to me, it is no longer needed, and they have been cut for about 7 years.
