Dynaspark vacuum line routing
Old Jun 2, 2005 | 10:01 AM
Roscoe's 85's Avatar
Roscoe's 85
Default Dynaspark vacuum line routing
I am installing my new Dynaspark into my 94 LT1. It went in and bolted up real nice. I'm just wondering about the routing of the vacuum lines. I know the line with the check valves gets connected to the intake manifold and the other line gets connected to the intake pipe before the TB. My question is in regards to where the lines route around in the engine bay. I used the metal retaining clip supplied to hold the two vacuum line together right off the Dynaspark. I have the check valve line running up and over the alternator bracket and along the other wiring harness and lines. Is this the best spot or should I route it under the alternator bracket? Is there any tricks to routing it. Also the other vacuum line has a clip to hold it onto something. Where does this clip onto? Pictures would be very helpful but not a must. Thanks for any help.
Old Jun 2, 2005 | 12:52 PM
R23HTC's Avatar
R23HTC
Routing instructions where provided with mine. My car is all apart right now, but when I get home, I'll see if I don't have some pics I could send your way. From memory, mine come straight up between the ALT. and water pump and where zip tied to one of the housing bolts on the alt. The flips over and into the air duct (hole you drill or use a later model duct) and the other goes to the intake. I believe that one was attached near my PVC.
Old Jun 2, 2005 | 01:22 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Does this help (F-body pictured)?
My factory vent runs beside the waterpump, and behind the pullies, you need to hold it to one side when tightening the bolts.
Old Jun 2, 2005 | 07:23 PM
R23HTC's Avatar
R23HTC
That's about what mine is set up like.
Old Jun 2, 2005 | 09:16 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Old Jun 2, 2005 | 09:23 PM
R23HTC's Avatar
R23HTC
Originally Posted by Ramrod92
Ramrod92, I have mine coming in on the top like the '95-'96s have. I'm not sure it's advisable to have it on the bottom side, as any moisture that might collect, would on the lower side of the duct. IMHO
To Dynaspark vacuum line routing
