Rear end seems loose
Old Jun 2, 2005 | 06:08 PM
c4_4ya's Avatar
c4_4ya
Default Rear end seems loose
I have just recently noticed that the rear in my '85 auto seems loose- while maintaining a steady speed down the interstate (say around 75) and letting off the gas seems to make the rear slightly sway to the left. Felt like a low tire, which the RR tire was low about 10 or 15 psi, but after inflation, it made no difference. It's barely noticeable to begin with, but just a little more noticeable while in a turn. I'm thinking worn bushings or wheel bearings, possibly worn shocks/struts (the car does have 180k on it). Any ideas?
Old Jun 2, 2005 | 07:27 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
If it were me I would change the rear end fluid and add 2 bottles of addative and have the front and rear aligned,first.
Old Jun 2, 2005 | 10:24 PM
harleyotis's Avatar
harleyotis
8th Gear
My 85 did the same thing. I am not sure of the correct name of the part so I will call them connecting rods. There are two on each side. They look sort of like a dog bone. The bushings were worn out on mine. Replaced them and problem went away.
To Rear end seems loose
