ET Calculation
Old Jun 2, 2005 | 10:04 PM
91superram's Avatar
91superram
Default ET Calculation
What would be my approx. 1/4 mile Et with 370rwhp and 380rwTq with a 3:54 gear and a sticky tire in a C4
Old Jun 2, 2005 | 11:15 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
FAST....
I would say some where between 12.931 @110.65mph
and 12.080 @ 112.84 mph .. That's figuring on a 3300 lbs (car + driver) weight and 370hp.
Check for your self
ET = (weight/hp)0.2841 x 6.9446 (The LRT Formula) 12.931 @110.65mph
ET = (weight/hp)1/3 x 6.269 (Geoffrey Fox's Formula) 13.001 @110.91mph
Then there is one more, the Patrick Hale's Formula.
That one gives you 12.080 @ 112.84 mph
Now looking back to what my car ran stock I would go with the Patrick Hales Formula. That one seems to come out closer to what it should be.
Old Jun 3, 2005 | 01:44 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your potential is low 11s.
Old Jun 3, 2005 | 05:33 AM
93 ragtop's Avatar
93 ragtop
That is 8hp more then I have. I have done 115.xx and 11.96 et. Now you did not say if it was a automatic, and if you have a stall converter. If so, and weather is good, etc. My guess would be mid to high 11's and 115-118 mph. But all of us are guessing. Find a track and go find out.
Old Jun 3, 2005 | 10:32 AM
VAHROOM's Avatar
VAHROOM
Default Or you can plug in some numbers
Go to Car Math and give it a shot.
Old Jun 3, 2005 | 10:50 AM
GeosFun's Avatar
GeosFun
Need to know a couple more bits of info:
1. Stall or launch rpm
2. RPM at max HP (this one is a biggee because it sets the torque curve)
3. If stick, need each gear ratio
4. Cubic inches
5. Shift rpm
Then I can plug these into Qtr Jr. Very accurate program Terminal mile per hour is a good indicator of HP. ET is not due to varying slipperyness of the track and suspension. The above posted estimates are pretty good. Should be mid-low 12's at around 110 depending on 1-5
Incidentally the Qtr Jr program sells for $95,
www.QUARTERjr.com. One of your best hi-perf investments. Puts many myth's to rest and eliminates shade tree guesswork I used it over and over on my 505 BBC altered roadster, injected alcohal and it was dead on once I got the input parameters right (many of us think we make more power than we really do). It is great for decision making on future mods, gears, converters, weight, whether to raise or lower peak HP/torque etc.
Old Jun 3, 2005 | 11:49 PM
bjankuski's Avatar
bjankuski
Mid to low 11's at 115 to 120 MPH. My 355 superram car with 342 RWHP and 380 RWTQ went 11.81 at 115 MPH.
Old Jun 4, 2005 | 01:21 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
That one uses the same "math" as the last one I posted.
You will run High 11's - low 12's (if you can drive)
Old Jun 4, 2005 | 06:25 AM
93 ragtop's Avatar
93 ragtop
fsr402, I wonder if the first 2 that you posted used flywheel hp instead of rear wheel hp. That might explain why they give a lower speed.
Old Jun 4, 2005 | 11:00 AM
65Z01's Avatar
65Z01
Yes, he needs to use HP at the crank in those equations above; I assumed ~3,350lbs of weight and 15% DT loss for my estimate.
Old Jun 4, 2005 | 11:18 AM
cv67's Avatar
cv67
St. Jude Donor '05
Get that bad boy out to the track!
Old Jun 4, 2005 | 04:05 PM
88BlackZ-51's Avatar
88BlackZ-51
with you driving? well i just read your other post and u ran a 12.5.
u should be doing better then that.................
Old Jun 4, 2005 | 04:19 PM
91superram's Avatar
91superram
Could only get a 1.7 short last night, with a 1.5 I should see a 12.3 but my concern is my MPH is down and I dont know why
To ET Calculation
