QA1 Coilovers
Old Jun 3, 2005 | 06:58 PM
mrgrimes's Avatar
mrgrimes
Default QA1 Coilovers
These seemed to be for drag racing, what other manufactures are there for road raceing that have coilover shocks for an 88 C4
Old Jun 3, 2005 | 07:27 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Looks like Exotic Muscle (http://www.exoticmuscle.com/vette/)
Makes them for your 88
eptaylor's Avatar
eptaylor
Default Shocking revelation?
Go to the General Corvette/Autocrossing and roadracing. They use them and have good info. Also ask about or look into what they call something like "semi-coil overs". From what I have been reading they have a variable rate as opposed to a single rate spring.
Old Jun 5, 2005 | 03:06 AM
Mo_Bandy's Avatar
Mo_Bandy
QA1 mergered with Carrerra, I love my Qa1's.... There are also Koni's as well
People are using them for both....
Mo
Old Jun 5, 2005 | 07:22 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I like the variable rate idea for a mainly street car.
Old Jun 5, 2005 | 10:46 AM
mothersworry's Avatar
mothersworry
I am going to start road racing as well. It seems to be a toss up on the Koni vs the QA-1. Koni makes a great shock. I went with the QA-1 because no one could say the Koni's were that much better and the QA-1 are easier to adjust in the rear. For the Koni you must either drop the rear shock to adjust or drill a hole in the frame to reach the adjustment. QA-1's are easy to adjust at the bottom of the shock.
Old Jun 5, 2005 | 11:47 AM
tigmaned's Avatar
tigmaned
i was thinking about doing this too. but one guy brought up a good point, coil over give you a 4 wheel indepent suspension, so then do you also take off the sway bars?? if you don't then do you have a 4 wheel indepent suspension??
Old Jun 5, 2005 | 06:21 PM
Mo_Bandy's Avatar
Mo_Bandy
I'm still running my sway bars... I never really thought abouttaking them off, I know some guys take the front loose for drag racing...
Mo
Old Jun 5, 2005 | 09:18 PM
eptaylor's Avatar
eptaylor
Default Keep swaybars
From what I have read the sway bars are lighter using the leaf springs because the spring itself contributes to some anti-sway itself. Therefore it might be wise to go to a stiffer sway bar with coilovers. Somebody who has experience needs to speak up and help out here.
Old Jul 2, 2005 | 06:04 PM
mrgrimes's Avatar
mrgrimes
Default are they mono tube?
I am looking at teh DDR4855B QA1 double adjustable shocks. (Proma Star) The QA1 catalog does not specify the design. Does any body have any experiance with shock fade and QA1 shocks?
Also I am looking at a 26mm sway bar in the rear, should this be a solid sway bar?
Old Jul 3, 2005 | 12:55 AM
Mo_Bandy's Avatar
Mo_Bandy
I don't autocross, extended driving I have never had even a hint of fade...
Mo
To QA1 Coilovers
