R&D cross frame is on
Old Jun 5, 2005 | 09:25 AM
99svrcpe's Avatar
99svrcpe
Default R&D cross frame is on
I installed it yesterday.. I was a pretty simple install, the hardest part was having to crawl in and out from under the car. It does seem to hang a little lower than I expected but it does add quite a bit more rigidity to the frame. Has anyone installed the behind the seat cross-bar? If so, How much more of an improvement was made?
Old Jun 5, 2005 | 09:39 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Nice, ain't it? Yes, I installed the cross bar first, then the camber brace and recently the cross frame. When I first installed the cross bar, it was a very noticable improvement. Besides being more ridgid, I noticed a much better feel on turn-in when hard cornering.
Old Jun 5, 2005 | 10:05 AM
96_LT1's Avatar
96_LT1
Thats a sweet looking C4
Im thinking about the frame for mine to, but i think ill try and get it on the road first!
Old Jun 5, 2005 | 10:08 AM
99svrcpe's Avatar
99svrcpe
Excellent! The cross-bar is next on my list then probably the camber brace.
Old Jun 5, 2005 | 10:13 AM
99svrcpe's Avatar
99svrcpe
Thanks! it wasn't cheap getting there...2yrs and $27K later (incl $13K purchase pice) but it puts a smile on my face every time I get behind the wheel.
Old Jun 5, 2005 | 10:19 AM
96_LT1's Avatar
96_LT1
Whats the spec?
Old Jun 5, 2005 | 12:16 PM
99svrcpe's Avatar
99svrcpe
Whats the spec?
on what?
Old Jun 6, 2005 | 12:08 PM
TM-Z06's Avatar
TM-Z06
I'd love the add one of those on my CE....but it's too low and the ground clearance is at a minimum
Old Jun 6, 2005 | 12:27 PM
hardlight's Avatar
hardlight
You can get it all welded in one piece now and there is a big improvement in ground clearance. I started with a Cross Frame, added the Camber Brace and then the S/T Frame roll bar. Wow what a stiff chassis...
Old Jun 6, 2005 | 04:26 PM
Lagoonatic's Avatar
Lagoonatic
Looks great! Thanks for the pictures. I have a cross-frame on order. Any tips on drilling the rear mounting holes for the nutserts?
Old Jun 6, 2005 | 06:15 PM
Gary04Z06's Avatar
Gary04Z06
Had Dave at R-D weld mine too. The Cross Frame really helps the handling.
I had the Cross Bar before I got R-Ds S/T Frame Support (aka roll bar), it really helped in the handling!
To R&D cross frame is on
