Rearend Click??
Old Jun 5, 2005 | 10:48 PM
jimkari's Avatar
jimkari
Default Rearend Click??
I have a 93 with the ZF-6 and 45K miles. Each time I shift into gear and let out the clutch I get a single click coming from the rear of the car. Thinking it might be the u-joints, I jacked up the car and try to move the 1/2 shafts. They both felt very tight with no movement or clicking noise at all. Any suggestions??
Thanks,
Jim
Old Jun 6, 2005 | 02:45 AM
bogus's Avatar
bogus
you might have a bad ujoint... even if it doesn't feel loose, it could just be worn out.
could also be a wheel bearing.
Old Jun 6, 2005 | 08:22 AM
JackDidley's Avatar
JackDidley
Id bet on the u-joint. Look for red rusty dust around the caps.
Old Jun 6, 2005 | 08:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My click was a dry, rusty spline where the halfshaft and bearing unit mate. Lubed with anti-seize and all is well
Old Jun 9, 2005 | 11:26 PM
jimkari's Avatar
jimkari
Thanks guys I appreciate the tips. I'll give it a try.
Jim
Old Jun 10, 2005 | 03:10 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I got my money on that.
Old Jun 10, 2005 | 10:27 AM
dchildress's Avatar
dchildress
I wish somebody would have given me this advice before I had ALL of my u joints replaced...half shafts and drive shaft. The lousy thing STILL clicks. I will give this a try.
To Rearend Click??
