R Dreikorn
Old Jun 6, 2005 | 01:31 PM
Russ Dreikorn's Avatar
Russ Dreikorn
Default Fuel filter replacement on 87 roadster
Is it necessary to remove the frame cross brace on an 87 roadster to replace the fuel filter? If not how do you suggest I get to the filter?
Last edited by Russ Dreikorn; Jun 6, 2005 at 01:44 PM. Reason: fuel filter replacement on 87 roadster
Old Jun 6, 2005 | 02:18 PM
bogus's Avatar
bogus
no.
the fuel filter is mounted on the inside frame rail, passengers side, near the engine.
It's a bitch, or, more accurately, can be a bitch.
You will need to remove the bracket and the 2 lines. I suggest removing the fuel pump fuse, running the engine as much as it will, and remove the cap to remove pressure from the lines.
Be careful... gas, as a liquid, burns.
