First code thrown in 20 years
Old Jun 6, 2005 | 06:52 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default First code thrown in 20 years
Just changed injectors on my 85 L98 and running great. Driving down the northway in upstate NY and oh no, check engine light goes on. 1st time since I bought new. It went off after awhile. When I got home I checked and it's a 32. ERG valve? Seems to run fine. Could this problem be a related to the new injectors?
What now?
Old Jun 6, 2005 | 11:10 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Can't see how new injectors would cause a code 32
This might shed some light(my 86 manual though)
http://members.shaw.ca/corvette86/Code%2032.pdf
Old Jun 7, 2005 | 12:08 AM
John A. Marker's Avatar
John A. Marker
When you changed out the injectors, did you use carb cleaner or a degreaser on the exterior of the intake manifold? If so, EGR valve does not react well to these cleaners. (Practical experience DAMN). You might have to replace it, my 85 still ran well once warmed up but still got the code 32. Changed out the EGR and all has been well since.
Old Jun 7, 2005 | 01:10 AM
MaxLean's Avatar
MaxLean
Most likely broke a vacuum line when doing the injector swap. Double check the vacuum lines and routing.
Old Jun 7, 2005 | 03:56 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Check the vacuum line that connects to the bottom of the throttle body. If not that, then at the egr valve itself, it may have come loose.
Old Jun 7, 2005 | 08:14 AM
rick lambert's Avatar
rick lambert
Don't know about 85, but when my 87 threw that code it was the EGR switch-cheap and easy to replace.
To First code thrown in 20 years
