closed loop,open loop, question
Old Jun 10, 2005 | 07:24 AM
Dartvader's Avatar
Dartvader
The ECM makes corrections in the injector duty cycle as the sensors feed back through closed loop. The amount of the correction is determined by the programer, and the speed with which the processor is sampling the feedback. This is also a programed value. If you modify your engine too far from the factory parameters, you must get a custom chip, or a programable ecm, to get your engine to run properly in closed loop, especially if your efi is speed density, which does not sample the air mass. Air mass systems sample the density of the air, and that is one more correction that the ECM can make, thus giving a wider range of acceptable parameters for the engine. Just for the record, if tuned correctly, open loop can be made almost as clean as closed loop, and it stays cleaner than a closed loop system that developes a bad O2 sensor,. That's why they do emmissions testing, and why the OBD is designed to flash a warning when these sensors act up.
