Does anyone reuse these bolts?
Old Jun 9, 2005 | 10:50 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Does anyone reuse these bolts?
When changing the rotors on one of these cars, you're supposed to discard the two bolts that secure the caliper bracket to the knuckle, as per Helms. Those bolts are damn near $6 a piece at my local GM dealer! 8 bolts (two at each corner)... that could get expensive and Mrs. eschoendorff might start asking questions.
Does anyone reuse them? Maybe with some blue loctite?
Old Jun 9, 2005 | 10:57 PM
Z51L9889's Avatar
Z51L9889
I've reused them in the past with no issues. Just clean 'em up and put loctite on them, and you should be fine.
Depending on how the bolts are used, some one-use bolts are "torque to yield", which means you actually deform the bolt slightly when you install it. It has much lower strength if you try to re-use it. Other types of bolts are defined as one use because they have threadlocker pre-applied. That's the case for the caliper bracket bolts.
Old Jun 9, 2005 | 10:59 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I've re-used them many times good lord I had no idea lol
Old Jun 9, 2005 | 11:01 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Many times with no problems. As mentioned above, clean and re-lactate, 2% Vitamin D is the spec I believe.
OOOOH he said loctite....
Old Jun 9, 2005 | 11:04 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I've reused them, but last time out I bought all new ones.
Old Jun 10, 2005 | 12:22 AM
eschoendorff
St. Jude Donor '08
Oh. Now that's some useful information. I figured that GM had its reasons.... but at $6 a bolt, I had to raise the question.
BTW... I didn't realize that my bolts lactate. Should I massage them gently before I remove them?
Old Jun 10, 2005 | 12:42 AM
Jet-Jock's Avatar
Jet-Jock
I followed the service manual and tossed them. They were much cheaper than that from Chris or GMPartDirect. Now the Circlips for the front pin THOSE are expensive.
Old Jun 10, 2005 | 01:58 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I bet it's CYA for GM due to the locktite. Better to charge more for bolts from Taiwan with locktite preapplied than to trust a service tech to do it right.
Old Jun 10, 2005 | 07:27 AM
Jet-Jock's Avatar
Jet-Jock
Its hard to say, then again they could be single torque bolts too. And considering its only that one bolt that secures the entire rear caliper, that tends to make it fairly important.
I figure they must have had good reason to state that in the service manual, so on those types of warnings I listen to them. Besides its not that much money. When I did mine, I install new pins, circlips and rear bolts. I think all the pieces where well under twenty bucks.
Old Jun 10, 2005 | 08:41 AM
c4cruiser's Avatar
c4cruiser
You should be able to re-use the bracket bolts two or three times then toss them. As mentioned, chase and the threads and apply BLUE locktite and torque to spec. If you were going thru lots of rotors for track days, I would replace them every other use.
Given the torque spec for the front bracket bolts, the bolt head may get rounded off quicker than the bolt itself will stretch or the threads get messed up. Definitely use a 6-point socket on them.
Old Jun 10, 2005 | 12:16 PM
Z51L9889's Avatar
Z51L9889
I used to work for GM. That's EXACTLY the mentality that they use. The other reason is liability. What happens if someone forgets to apply loctite, the bolts back out, the brakes come off, and someone dies? I know this sounds really silly, but I've actually seen GM get sued for reasons that were at least this stupid.
Old Jun 10, 2005 | 12:50 PM
SunCr's Avatar
SunCr
I've reused them without any problems on every car I've owned. I think the Pins are more important since once they're corroded, the caliper can hang up, but I usually just buff those up too and then reinstall them.
Old Jun 10, 2005 | 03:21 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
This is good info, fo sho'.
Larry
code5coupe
Old Jun 10, 2005 | 06:37 PM
Jet-Jock's Avatar
Jet-Jock
I understand the point your making, but the GM Service center should be sued if they performed the maintenance and didn't follow proper procedures causing damage or harm to the vehicle and owner. I wouldn't call that a stupid reason. Sometimes that is what it takes to make big companies make changes.
I mean that is probably a no-brainer to a good mechanic, especially if the understand the system and know that only one small bolt holds this assembly together. It should be torqued and locktite applied.
It would be an engineering process specification. During development they probably noted that the bolt was backing out over time and wrote a process spec to deal with it. I use to see this alot with aircraft systems, except on many of those critical fasteners, they wire tie them after torqueing them.
Old Jun 10, 2005 | 08:37 PM
Lone Ranger's Avatar
Lone Ranger
I thought you were supposed to use red thread lock formula (loctite) on stud bolts?
Old Jun 11, 2005 | 09:00 AM
Atok's Avatar
Atok
These bolts just might be "torque to yield". Have you noticed in the service manual the torque spec is 166 lbs.ft.! Then I noticed in the back of the 5B2 section (rear brakes) it lists Bracket Mounting Bolt as 70 lbs.ft. which seems more reasonable for a bolt of this size.
I torque mine to 100 lbs.ft. with red locktite and never had a problem.
Old Jun 11, 2005 | 10:34 AM
c4cruiser's Avatar
c4cruiser
You could use the red loctite, but you need to apply heat to the threads to release it.
As far as bolt torque, the rear caliper mounting bracket bolts are torqued to a lesser amount (70 ft-lbs) while the front bolts are torqued to 165 (+/- 15) ft-lbs. 84-87 cars use a slightly lesser value on the front bolts.
To Does anyone reuse these bolts?
Old Jun 11, 2005 | 10:39 AM
Jet-Jock's Avatar
Jet-Jock
Gosh if I remember correctly the new bolts had greenish looking locktite (or equivalent).
Old Jun 11, 2005 | 01:35 PM
pwrful c4's Avatar
pwrful c4
I have reused them with no problems.
Old Jul 9, 2005 | 03:17 PM
YellowZ's Avatar
YellowZ
1st Gear
If you follow GM's service manual for a '91 Vette and torque the front caliper bracket bolts to 166 ft. lbs. you'll snap the bolt! I just did. Chilton's and others recommend 133 ft. lbs. which is more reasonable for an aluminun bolt.
