CAT air hose ?
Old Jun 11, 2005 | 12:45 AM
6speedshifty's Avatar
6speedshifty
Default CAT air hose ?
I just installed pipes on my '90 that eliminated the pre-cats. Now it throws a code 32 while cruising at about 45mph. Could this be caused by the lack of pre-cats and new pipes?
Also, I currently have the air supply hose disconnected from my main catalytic converter. Could this cause any problems other than not being smog legal? Thanks for the help.
Old Jun 11, 2005 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did the headers eliminate the egr pipe?
Have you checked to see if the wire has come off the egr switch?
Vaccum lines to egr are on and intact?
This is from my 86 manual but may shed some light............... http://members.shaw.ca/corvette86/Code%2032.pdf
Old Jun 11, 2005 | 12:27 PM
vader86's Avatar
vader86
Code 32 is EGR, so you have to leave those pipes intact. The EGR activates when you spend alot of time at part throttle and when the coolant reaches 170, which is why you see it throwing a code when on the hwy.
Old Jun 11, 2005 | 11:57 PM
6speedshifty
I just put a new EGR valve on it a couple months ago and it passed smog 2 weeks ago. It has the stock headers on it and everything seems to be hooked up... Except for the air hose to the main converter. Will having that disconnected cause any problems? Thanks for the feedback.
Old Jun 12, 2005 | 12:08 AM
vader86's Avatar
vader86
The EGR system is sensing a loss, the disconnected pipe must be reconnected, if everything else is fine then this is the culprit.
However, its not detrimental to engine performance, so its not really a big deal to worry about.
Old Jun 12, 2005 | 10:13 AM
rick lambert's Avatar
rick lambert
More often than not you'll find the switch is bad-cheap and easy to replace-I'd start there.
To CAT air hose ?
