Looking for brake system specs...
Old Jun 17, 2005 | 05:43 PM
HansB's Avatar
HansB
Navigator
Default anyone know the stroke?
bump...
Old Jun 17, 2005 | 05:56 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The displacements/strokes don't necessarily have to be the same.. it depends on the springs inside the cylinder.
http://auto.howstuffworks.com/master-brake1.htm
The stiffer primary spring, the less fluid is displaced to the rears. Also keep in mind this part has nothing to do with the bias though (supposedly).
Old Jul 11, 2005 | 03:33 PM
HansB's Avatar
HansB
Navigator
Default hmm, I see your point...
Actually I would also think the springs are there to make sure the pistons are pushed back into start position when the brake goes back to the start position, especially incase of a leak in one of the brake lines. However, I understand how you mean when you say the stroke can be different between the front and rear brakes :-P
Never mind the stroke, anyone have the MC primary/secondary diameters in their handybook?
Regards, Hans B
Old Jul 12, 2005 | 01:27 PM
LaVidaLoca's Avatar
LaVidaLoca
If you decide to do a J55 conversion let me know. I did it to my 85 and can help you with the adapter brackets you will need.
Old Jul 12, 2005 | 02:07 PM
tempest's Avatar
tempest
sorry to hijack the thread, but anyone know how much performance difference between J55 and the C5 setup? trying to decide on upgrades myself, and i would have to spend extra $$$ on A-molds if i go C5.
