Looking for brake system specs...
Old Jun 11, 2005 | 04:07 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Looking for brake system specs...
Looing for info on the different brake options offered. J55, 12", 13".... were the rears upgraded with the big brake option?
I can't seem to find this info. I need piston and rotor sizes mainly.
Old Jun 11, 2005 | 04:43 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
J55 88-96 Dual piston 13.0" x 1.1
JL9 88-94 Dual piston 12.0" x .75 it seems just by going the difference in the caliper throat
All 88-96 cars had the same caliper/rotor Single piston 12.0" x .75" rotor (not sure on the thickness, just going by what I remember being a joke)
84-87 Single piston calipers front and rear. From what I understand smaller rotors as well.
Unsure of the piston sizes, I used to have it written down before I went to the Big Reds trying to figure out fluid displacement.
Old Jun 11, 2005 | 08:56 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It's always been my understanding that the optional brakes were strictly a front rotor size upgrade, which also takes a caliper with a wider opening. I'm not sure if the piston size in these calipers is different or not. All C4s have 12" rears.
Old Jun 11, 2005 | 02:37 PM
VenkmanP's Avatar
VenkmanP
Some of the info is here:
http://www.superchevyperformance.com.../c4brakes.html
Look at the C5 page also, it has pics of C4 rotors.
Old Jun 11, 2005 | 02:42 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by Jeffvette
All 88-96 cars had the same [rear] caliper/rotor Single piston 12.0" x .75" rotor (not sure on the thickness, just going by what I remember being a joke)
I just measured my rears, since they're conveniently lying on the floor, and they are indeed 12 x 0.75
Old Jun 11, 2005 | 03:00 PM
VenkmanP's Avatar
VenkmanP
Just realized I have a rear piston out also. Don't have calipers here, but it's roughly 9/16"
Old Jun 11, 2005 | 03:34 PM
Z51L9889's Avatar
Z51L9889
I have my brakes torn apart right now also. I'll measure the pistons and post the info later tonight.
Old Jun 11, 2005 | 05:56 PM
CentralCoaster
Thanks guys! I also think there's some specs on brake line pressure w/ 100# force on the pedal. It's in either the dealer specification manual, or the brochure.
Old Jun 11, 2005 | 06:46 PM
HansB's Avatar
HansB
Navigator
Default Mastercylinder info? (hijack warning)
I'm sorry CentralCoaster if I hijacked your thread
Anyone of you gentlemen know the Mastercylinder info aswell? I'm looking for the bore and stroke for a 90/91 brake MC.
Kind regards, Hans B
Old Jun 11, 2005 | 06:50 PM
Z51L9889's Avatar
Z51L9889
J55 front piston size is 1.47" (37mm). The base brake caliper has the same size pistons. Rear piston size also appears to be 1.47", but it's tough to get a good measurement. Just for reference, C5 front piston size is 1.54" (39mm).
Old Jun 11, 2005 | 07:49 PM
VenkmanP's Avatar
VenkmanP
That's odd. I'm pretty sure the JL9 and J55 rears are the same. Never seen different part #s for them.
Here's my rear piston.
Old Jun 11, 2005 | 10:49 PM
CentralCoaster
The stroke is difficult, since there's the primary and secondary piston. I don't know if they have the same amount of travel, the front might have more since the front pistons hold more...
I have the rear stroke, and the bore written down somewhere for my 85.
Old Jun 12, 2005 | 12:08 AM
Z51L9889's Avatar
Z51L9889
You're right -- 88-96 rear brakes are the same for all models.
I don't think that is the primary hydraulic piston -- I believe that is the plunger for the parking brake. I don't have a diagram in front of me, but I think the plunger sits down inside the main hydraulic piston when the parking brake isn't set. I measured under the dust boot right where it meets the caliper body.
Old Jun 12, 2005 | 01:00 AM
VenkmanP's Avatar
VenkmanP
You're right!
I'd never seen a caliper like this one before - now it makes a lot more sense!
Old Jun 12, 2005 | 01:26 AM
VenkmanP's Avatar
VenkmanP
OK, now that I'm looking at the right thing...
Looks like 39mm.
Old Jun 12, 2005 | 03:55 AM
CentralCoaster
How thick are those rear rotors? Seems like the integral parking brake would be a great way to upgrade the rear rotors... since it always involves tossing my drum ebrake.
Old Jun 12, 2005 | 12:04 PM
Z51L9889's Avatar
Z51L9889
Rear rotors on 88-96 are 3/4" thick.
To Looking for brake system specs...
Old Jun 12, 2005 | 12:05 PM
Z51L9889's Avatar
Z51L9889
Looks like 39mm.
Thanks for checking the piston by itself. My caliper is still assembled and I estimated the measurement through the dust boot.
Old Jun 12, 2005 | 12:29 PM
VenkmanP's Avatar
VenkmanP
Thanks for pointing out my cluelessness! I thought I had the thing disassembled and the main piston was still in there!
I did think it was a pretty weird looking piston, but hadn't looked closely enough to figure it out. Hopefully I would have noticed my mistake when I went to install the new seals, but who knows.
Old Jun 13, 2005 | 02:00 AM
HansB's Avatar
HansB
Navigator
Default stroke / bore?
Hmm, I haven't taken a C4 MC apart, but since the front calipers has dual pistons and the rear has single (big area differense), I expect that there is a bore differense in the MC between the primary and secondary pistons to compensate for that? However, the stroke should be the same because they are "inline" (or am I wrong here?)
Regards, Hans B
