Im doing the C5 upgrade on the front brakes and also replacing all the brake lines. I was wondering if I should rebuild the rear calipers (already bought the kit but dont know how much of a pain it is)?
The car has around 150k miles and I dont think the seals have been replaced in those rear calipers. I have to take them off anyways to replace the lines. Should I go for it or leave it alone?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That depends, mileage is not a big issue, IF the fluid has been flushed regularly. Fluid contamination is the most common cause of hydraulic problems in a brake system. If you do decide to use them as is, flush the system before removing them, particularly if you're replacing the pads and will be pushing the pistons back in. Some calipers are a bit more of a pain to rebuild than others, but most aren't too bad. Usually the main pain is getting the pistons started back in.
From: No more yankee my wankee, the Donger is tired!
The rear calipers on the 88-96 cars are not easy, but they are not hard. It is mainly due to the parking brake mechanism that is built into the caliper.
The rebuild kit also includes some parts for the parking brake. I agree though, flush the system before you remove and rebuild.
I'm curious now. How does the parking brake system differ on the early cars?
84-87 uses a drum style that sits in the inner portion of the rotor hub. Similar to the C5.
So now let me ask the next question and probably answer it too. If one changed the rear to the early style to make a rear C5 set-up possibly easier and cheaper, he'd probably end up with the earlier wheel offset too, hence screwing everything up, right?
Apologies for the flagrant thread highjacking BTW....
Replacing the seals is simple. I did it on my car recently when I had the rear apart for a gear change.
My bores had noticeable wear at 70k, so at 150k I'd expect yours to have substantial wear. If it was my car at 150k I'd be thinking about new calipers rather than just replacing seals.
Just checked at gmpartsdirect, $300 for the rear set shipped, ouch. I'd order from Superior Chevy though gmpartsdirect takes forver.
On a side note, it seems like I go through pads pretty fast. I go through the rears about every 18 months and my 94 is a daily driver. I use stock pads... could it be the calipers or my lead foot?
$250 shipped from ac-direct. $250 every 150k is not much.
You'd have to tell us your annual mileage. If you're going 60k in 18 months then it's normal.
