hopefully i will get some pics soon, but i will try to descride where it is. it is the sensor on the pipe that is on the passenger side rear of the engine. the pipe goes from the exhaust manifold to the intake manifold. i cant seem to find where the electrical connection on this pipe get connected to....come someone take a picture for me or tell me where to put it?
Look for a Grn wire that disappears down behind the right side of the dist.
The connector is on the left side of the dist very near the large harness running across the top of the bell housing behind and below the intake base. The wire lead is so short that it's almost impossible to get at it with the base on the engine.
If you ever have the intake base off I think a very good mod is to cut off that connector, splice a length of Grn wire to the stub and run the connector the connector up to the right side of the dist where you will have easy access when you need to change the EGR Temp Sensor.
