Starter Interrupt Relay
Old Jun 11, 2005 | 03:55 PM
Simul8's Avatar
Simul8
Default Starter Interrupt Relay
Where is the starter interrupt relay located on a 84.
A friend of mine is looking to bypass the relay due to security problems he has been having.
Old Jun 15, 2005 | 07:43 AM
Simul8's Avatar
Simul8
ttt
anyone?
Old Jun 15, 2005 | 10:24 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
You should consult a service manual for your specific year, but I believe they are in the dash behind the Digital Information Center.
Old Jun 15, 2005 | 11:46 AM
LaVidaLoca's Avatar
LaVidaLoca
Pull the center dash panel and the information center. It is behind them. The 12 volts to the starter goes thru the relay so the security system can prevent the car from being started. I bypassed mine because the contacts were intermittant
Old Jun 15, 2005 | 12:23 PM
nitronick's Avatar
nitronick
Hey Yukon!
Old Jun 15, 2005 | 09:42 PM
Simul8's Avatar
Simul8
Thanks, I'll let him know.
Old Apr 3, 2015 | 09:21 PM
jpeters11's Avatar
jpeters11
I need to bypass the starter interrupt relay on my 84 to.. the connecter to the relay is broke and it won't start. How do you bypass it?
Old Apr 4, 2015 | 02:23 AM
Cliff Harris's Avatar
Cliff Harris
Check the picture in this video intro:
The older cars that don't have VATS use the same relay. It's just controlled by the TDS system instead of VATS and does the same thing.
To Starter Interrupt Relay
