Does anyone know why Corvettes use large caps on the distributor and steel plenum extensions as F bodys use small cap and plastic.
My troublem shooting manual state that poor ingnition sheilding can give ecm false rpm readings and send false fuel ratios causing a car to run rich.
I have a C3 that is using small cap with remote coil that runs rich and wonder if anyone knows why GM used two systems.....
