Starter Wiring
Old Jun 12, 2005 | 12:14 PM
dock351's Avatar
dock351
St. Jude Donor '06
Default Starter Wiring
90 L-98
I replaced the starter. I want to make sure about the wiring to it.
there are two connectors, one bolt for power, the other is a screw, for ground, I think. There is a power wire from the battery i believe goes to the bolt, and two more wires, a small diameter wire and a thick black wire that loops over the engine: I think this goes to the ground.
Does this make sense? Let me know if you need more into.
thanks!
Old Jun 12, 2005 | 02:22 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Mark,
There is no ground wire except for the little ground strap between starter motor and solenoid.
The large connection is 12v from battery. The small connection is from ignition key.
Starter is self grounded when mounted.
Dave
Old Jun 13, 2005 | 12:15 AM
dock351's Avatar
dock351
St. Jude Donor '06
thanks again, Dave!
we are almost done up here. engine in, rear end in, drive shaft in, c beam all but in, just doing the details.
Old Jun 13, 2005 | 01:39 AM
skateparkdave
Sweet, keep us posted and let us know when you get done.
To Starter Wiring
