I need Roller Rocker advice
I have centerbolt valve covers, what do I need to look for to make sure they will fit properly with my valve covers? With 1.6 ratio rockers will I have any clearance issues with standard aftermarket Chevy valve covers?
Also what is the major advantage of the bigger rocker studs? I bought a set of used heads and they already have them installed. If I find a smokin' deal on a set of 3/8 stud rockers is it possible to go back to that size? Or is that not a good idea?
When installing RRs onto the #113 heads ('88-'91) you will need to pull the factory non-hardened guide plates, which requires removal of the rocker studs. For me this made it a no-brainer to go with 7/16" studs and matching RRs. These thicker studs reduce deflection at high rpm and so maintain full valve lift.
Also, since the OEM guide plates are comming our anyway, just go with hardened guide plates & push rods and get non-self aligning RRs. These are only $260 compared with over $300 for self aligning, so about the same either way.
Also install new valve springs and machined keepers and set seat force to around 110lbs (stock was around 85lbs!!).
He said that while they are lighter (have less inertia) than a steel rocker...including the cast steel roller rockers...they have lower fatigue strength. This means that unless you plan to replace them regularly (which is what the race teams do), you risk losing one. For street use, ol' Smokey liked steel units.
Hey, he said it...not me.
The seller should be able to tell you which valve covers his rockers are compatible with. If he can't, find another source.
Larry
code5coupe
I had to reduce the height of the drip tabs in my stock '88 valve covers as well as narrow the bolt towers to get the valve covers back on over the ProMagnum 1.6:1 RRs. But that's no big deal with only a Dremel tool.
I like the idea of roller rockers and heard 1.6 ratio on an otherwise stock engine makes virtually no difference. So maybe I'll pick up a set of 1.5 if I don't need to cut my valve covers.
I still don't like the idea of cutting my drip tabs so that's good if they'll fit under the composite covers. Does anyone know for sure?Thanks
Comps Hi-Tech and Pro Mags, Crane Gold, Crower SS and of course the GM LT4 rollers aka Cranes will all fit without any issues under the composite LTx valve covers. Scorpian, Pro-Form, Summit are chinese rockers, also there are the CAT rockers now that copy the Comp Hi-Tech SS rockers, these are also Chinese. I can tell you that the copy is very good as far as visually goes, they look nearly identical to the Comp Hi-Tech which goes for nearly $400
but they sell for nearly half of what the Comps sell for. But for me I wouldn't risk a big dollar engine with a $200 savings for cheap rockers that may or may not break. At least not until they are proven to me that they are OK.I often wonder what the acronym CAT means......Chinese Auto Tech maybe
Not saying anything bad about Chinese, obviously I am Chinese, only that I have worked in China and have seen how cheap and how crappy their QC is, but at the same time I have also seen parts equal or exceed that of US made parts as well.....
Yes, and it's not like you can't buy good AND junk parts made in the USA too. But definitely don't scrimp here. I saw a set of Proforms begin to just fall apart after only a few thousand street miles. They were properly installed and adjusted in an otherwise healthy engine and did not see excessive RPMs.
Also, a related question, does the LT4 springs (oval section) require a special valve seal? I'm thinking not but I just want to confirm my assumption.
