Installed The 52MM TB Today
Old Jun 12, 2005 | 09:35 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Installed The 52MM TB Today
I finally got around to cleaning up the 52mm TB i bought from Draven.
Yes, i noticed a definite improvement in performance. I bought it in the hopes that whoever bored it put in sealed bearings in the shaft bores. Draven didn't know but for the price i decided who cares. If the shaft bore is in better shape than mine and it's 52mm with a the infamous AIR FOIL, i can't cry
The throttle plates had a little binding when closed so i took a little emery to a few spots on the edges and it works smooth now. My idle doesn't take so long to return now and the performance improvement is good. Here's a few pics
Here is the 48 with the 52
The "No turning back bypass" installed on the 52
The 52 cleaned up
Old Jun 12, 2005 | 10:32 PM
BlackC6LS3's Avatar
BlackC6LS3
looks good....how do you change the shaft bearings....they seem shot on my trans am and i was contemplating buying a new (used) tb but if i can just replace the bearing that would be a lot better.
Old Jun 12, 2005 | 10:38 PM
JackDidley's Avatar
JackDidley
Looks like you got a good deal. Will you make it to the dragstrip and get some numbers for us ?
Old Jun 12, 2005 | 10:43 PM
vader86's Avatar
vader86
Either dyno or ET numbers please.
Old Jun 12, 2005 | 11:31 PM
AGENT 86's Avatar
AGENT 86
Dave Koldos and others bore the shaft bore to accept a sealed bearing and will bore your 48 to a 52 if you like
Old Jun 12, 2005 | 11:35 PM
AGENT 86's Avatar
AGENT 86
I'm going to make it sometime this summer. Never been before so i can't compare #'s. I will take both TB's and compare
Old Jun 12, 2005 | 11:52 PM
arrow322's Avatar
arrow322
Sounds any other mods to help ie air intake or afpr etc.. I have contemplated this but wasn't sure if it was worth it without some other mods
Old Jun 13, 2005 | 01:08 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
How about some datalogs?
Old Jun 13, 2005 | 01:18 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I knew when I saw the first pic of the TB that before the progression of pictures was over, it'd be nice and clean. I had a 58 on my car for a while. Didn't really like it although it may have helped on the big end. I've got a modified to 52 stocker on the way and now I'm even more anxious to get it on.
Old Jun 13, 2005 | 01:19 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Glad you are satisfied with the change.The stock TB is usually more than enough to feed most engine mods.So I hope it gains you some power.
Old Jun 13, 2005 | 02:13 AM
Dan Parker '96's Avatar
Dan Parker '96
I also recommend David Koldos. His work is exceptional.
As far as a performance gain going from 48mm to 52mm, you'll see none. At least as far as an LT4/Hotcam combo cares. Data logging may show a slight increase in MAP pressure but it's not realized by the rest of the package.
Old Jun 13, 2005 | 04:22 AM
Draven's Avatar
Draven
St. Jude Donor '14
Glad it worked out well for you, Mr. Agent. : )
I saw my name in the thread and for a second went "WTF!?" but then I remembered. Looks nice and shiney now.
Enjoy!
-Joe
Old Jun 13, 2005 | 08:27 AM
AGENT 86's Avatar
AGENT 86
It may be the placebo affect but i do notice a difference. I'm not saying it adds gobs of extra power but it has changed the way may car reacts. What i noticed was when stomping the pedal with the rpm in the 3000 area the engine had more grunt and would clime to 5000 rpm quicker than before. Call me crazy but when cruizing at about 50 mph and stomp it now it's almost like the feeling of the auto kickdown of my 4+3
Old Jun 13, 2005 | 09:11 AM
mitchcole's Avatar
mitchcole
The throttle response is much faster with a larger bore throttle body. The manifold hits zero vacuum at a lower throttle position. It's a similar effect of changing the throttle body cam so that it's not linear. (4 banger cars in the 80's did this alot to make them seem more powerful than they were. The first inch of pedal opened the throttle blades 50% the remaining 4" of travel made it to 100%.)
In terms of absolute power - I've heard that they don't help at all till the mods are over the top.
Now that I've poo pooed all your hard work - it does look awesome!
Old Jun 13, 2005 | 09:41 AM
Steel Blue 91's Avatar
Steel Blue 91
Even if you choose not to admit it.......it's the air foil
Old Jun 13, 2005 | 11:32 AM
Jim85IROC's Avatar
Jim85IROC
When my TPIS-52mm throttle body started to stick, I swapped it for a 48 and the difference is exactly as you describe. The 52 "felt" faster because it took less throttle input to make power, but at WOT there is no difference. Even still, I preferred the 52 just because it "felt" more powerful during daily driving.
Old Jun 13, 2005 | 01:45 PM
LT4BUD's Avatar
LT4BUD
A "slight" increase in MAP ought to produce more power....same as a higher barometer reading ought to produce more power.......cooler air ought to produce more power.......
I really don't understand your comments.....it is still my thinking that you don't want your MAP to drop at WOT, so if a bigger tb shows an increase in MAP at WOT the bigger tb was beneficial.
A perfect intake, IMHO, would be if the MAP reading stayed constant from low rpm to max rpm, at the same value as the barometer or MAP with the motor off
To Installed The 52MM TB Today
Old Jun 13, 2005 | 01:51 PM
LT4BUD's Avatar
LT4BUD
Why didn't you like it????
Did you bore your intake openings out to 58mm??? A 58mm tb on 52mm openings doesn't work......seems to cause turbulance in air flow making the 58 worse than the 48....
Old Jun 13, 2005 | 04:28 PM
boulderlt4's Avatar
boulderlt4
I got some gain on rwhp and rwft/lb with my 58MM! About 5-7.
http://forums.corvetteforum.com/show...bk&forum_id=48
Old Jun 13, 2005 | 06:05 PM
Corvette Kid
Yes, the intake's fully ported including having had those openings enlarged. It just wasn't as snappy in the normal driving range. After I build the stroker bottom end and install it, I'll be going back to the dyno again. The 52 will be on the car and I'm taking the 58 along to do a comparison after the tuning is tweaked for the increased cubes.
