Shift Light - Code 72
Old Jun 14, 2005 | 10:04 AM
C4-383's Avatar
C4-383
Active Streak: 90 Days
Default Shift Light - Code 72
New to the forum - Hope I do this right. Have a 90 C-4, 383 engine, 373 rear end gear. At 70mph (actual) speedometer reads 79-80mph. Also tach reads approximately 800 RPM high. From time to time shift light (on left side of dash) comes on (car does go into overdrive). Checked code and it showed a 72 (Gear Selector Switch Fault)
Any thoughts, suggestions will be appreciated.
Enjoy the forum and all the help.
Old Jun 14, 2005 | 10:16 AM
C4-383's Avatar
C4-383
Default 700R4 Transmission
Forgot to add - transmission is 700R4 Auto
Old Jun 15, 2005 | 02:36 PM
C4-383's Avatar
C4-383
Default Code 72
No ones had a code 72 or shift light issue?
Old Jun 15, 2005 | 07:49 PM
SunCr's Avatar
SunCr
No - but I've had bad gear selector codes on other GM's which entailed adjusting the switch - particularly after R & R'ng the tranny. As far as I know, the 72 is loss of the speedo signal and I thought you would use the VSS Trouble Tree charts - maybe someone has one you can look at.
To Shift Light - Code 72
