Alignment Issues
Old Jun 14, 2005 | 04:38 PM
dan6712cc's Avatar
dan6712cc
Default Alignment Issues
I've had my '94 aligned 3 times in the past month and it still pulls to the right. I think the problem got worse after I put on some 9 and 11 inch OE ZR1 wheels on but Im not sure. Also recently had all the bushings replaced with poly, had another alignment done and it still pulls to the right. I have to hold the steering wheel about 15-20 degrees to the left for it to go straight. Ive tested on many roads so I know its not the angle of the road.
One shop told me the tread on my tires is probably misaligned? Any ideas?
Old Jun 14, 2005 | 06:18 PM
WildBill95's Avatar
WildBill95
Check your tires to see if they are going in the right direction . then check upper and lower ball joints , then check your tie rod ends front and rear . Any of these can cause your problem.
