Fuel Injectors - the dreaded "hard start when warm"
Questions:
1. Are injectors difficult to replace - can I do this myself. My technical / mechanical ability is about a 6 out of 10 and improving the longer I own this car. I do my own oil changes, changed the fuel filter last weekend, removed and cleaned TB and IAC, etc.... I couldn't find a tech tip on this procedure. Does anyone have a documented procdure? I know I know...buy a helms manual....
2. Can I clean / refurbish my existing injectors? or is this a "replacement is the only option" project.
3. I have read posts on whether to stay with 24lb. injectors, Bosch vs. Accel etc. It seems that staying with 24lb. and getting the Ford injectors are the best option. Please tell me if you disagree.
Thanks for your input guys!
Sorry guys...yes, it's a 91 - L98.
shouldn't be too hard to change them even if you were a 3-4 out of 10
i don't think YOU can do anything to clean/service/flush them yourself - but you can have it done - i am in need of the same thing on my LT1 and i am just going to replace all 8 of them it would be easier and save me time i think in the long run.
2. Not yourself, contact Rich at http://www.cruzinperformance.com/
3. If you want NO downtime, buy another set. Otherwise just get yours cleaned up.
FYI I saw it posted that sending L98 stock Multec injectors to Cruizin for cleaning was not recomended. Get new ones from five o.
I intend to hook up a fuel pressure gauge and check the pressure. Then check each plug for gas. I read a few days ago about lifting the fuel rail up and being able to see what injector is leaking.
Is the other sensor there for the cluster coolant gauge?[/quote]
Yes, one of two. That is the one the ECM actually sees while the other one between cylinders 6 & 8 is what displays on your dash.
Aardwolf... any idea why it was suggested not to send them to Cruizin for cleaning?
As for down time...the hard start is not so bad that I need to do this now...so I could wait until winter when the car is tucked away in the garage and do it then.
Above is the thread about the Multec cleaning. Cleaning looks worth it if none need replacing. If one or more were bad then it puts the cost right there by the cost of new ones. fiveomotorsport.com has good deals. Maybe if you called Cruizin they would give a good deal on replacing a stock injector. It'd be worth a try if you want to stay with Multec. Does Cruizin sell new injectors? Their webpage is limited.
Scorp, I disconected the sensor on the passenger side of the engine under the TB and no change with starting. So the dash coolant sensor is on the drivers side of the engine by 6 and 8. I figured that one was for the ECM.
