What to buy?
Old Jun 15, 2005 | 02:35 PM
Admrl94's Avatar
Admrl94
Default What to buy?
So I have a '94 coupe with Corsa cat-back and cold air induction, everything else stock. What should I get next? Debating between:
1. 52mm throttle body
2. JET tuning module
3. pulleys
4. front/rear power couplers
Anyone recommend some of these or are there other things I should consider? Looking to spend around $800.
Old Jun 15, 2005 | 02:45 PM
vette&f-bod lover's Avatar
vette&f-bod lover
1.unless yours is real dirty with buildup(which you can just clean with TB ckeaner)wont do anything noticeable for a stock engine
2.will just make your fans come on earler
3.will free up alittle,just not worth the $
4.if you are talking about the bellow that goes between the mass air,and air intake,unless yours is ripped,it wont do much of anything.
Old Jun 15, 2005 | 02:47 PM
vette&f-bod lover
give some more info,what trans,gears do you have?miles state of tune etc.
Old Jun 15, 2005 | 02:54 PM
Admrl94's Avatar
Admrl94
Auto, stock gears (3.07s?), 34.7K miles, haven't had it tuned so don't really know.
Cold air induction is from SLP. I've only had the car for less than 2 months and am looking to boost performance for the occaisonal stoplight...not looking to auto X or drag it (well, may try this once to see what it's like).
Would headers be extremely loud??
Hopefully this helps!
Old Jun 15, 2005 | 02:58 PM
JoeyGibson's Avatar
JoeyGibson
go with 3:73 gears and 11 inch grand sports wheels, you won't believe how the car will wake up, my brother did this to his otherwise stock '93, it really launched hard.
best bang for the buck.....no question about it !
Old Jun 15, 2005 | 03:21 PM
Red Tornado's Avatar
Red Tornado
Originally Posted by Admiral1
.....Would headers be extremely loud??....
headers will set the stage for a cam upgrade and ported heads, which is probably all you'll want for a dd LT1.
As for loudness this is impossible to comment on, as its purely an individual decision. I'm very happy with plenty loud
Old Jun 15, 2005 | 03:41 PM
Midnight89's Avatar
Midnight89
Originally Posted by JoeyGibson
go with 3:73 gears and 11 inch grand sports wheels!
I agree!! I can't vouch for the gears, but I will definitely attest that going to 11" rears with Nitto drag radials was the best "bang for the buck performance modification" that I've done to date. My 60ft times are consistently 3/10 - 4/10ths lower since the change (I was running Michelin Pilot Sports wrapped around the stock 9.5" wheels before).
Old Jun 15, 2005 | 03:44 PM
hz900's Avatar
hz900
Many people with auto LT1 cars have put in a better torque converter and lower (3.73 is the lowest you can go in a auto I believe) gears and said it was like night and day.
Old Jun 15, 2005 | 05:00 PM
Lichen's Avatar
Lichen
I would recommend 3.54 gears and a 2400-2600 stall converter. But unless you do the work yourself, it's going to run you more than $800. Long-tube headers would also be a nice choice, and they won't make it that much louder, depending on what exhaust set-up you go with.
Old Jun 15, 2005 | 06:43 PM
Admrl94's Avatar
Admrl94
Thanks for the comments.
So I'm pretty much hearing gears as being the best upgrade. I looked into it before and know they're about $1100 pre-installation depending on where you find them. What should I expect to pay to have someone put gears in?
And how do I post pics of my car/put them in my avatar? Sorry I'm a noob on here.
To What to buy?
