I'm doing tuning and need to keep pulling my chip but I'm leery of leaving the ECM sitting on the floor - that may be why my current computer is acting oddly (I have a feeling it got stepped on). So I'm wondering if anyone has tried running a short ribbon cable to the socket on the ECM and plugging the chip into a new socket and maybe mounting it on the hush panel out of the way. I realize there's a potential timing issue with adding additional wires in-line, but since these are pretty slow computers maybe I could get away with 6-10" or so?
Thanks.
[RICHR]
Thanks.
[RICHR]
It has been tried, no one (as far as I know) has gotten it to work, signal loss along the wires seems to be the problem.
Adding wire length to that part opens it up to a ton more RF. The PC board engineers spend countless hours designing the PC board with filtering caps and multi-layered ground plaining to reduce the RF to the chips just to make it work in that harsh enviroment.
My cousin owns , runs , and is the chief Engineer at Digital Delay Inc. I see what he goes through with every new product he puts out and it is amazing what he has to do to keep the processors from getting scrammbled. He is so good at what he does, a few years back, NASA called him to discuss an issue they were having with some "thing" or other.
You racers out there might recognize the "Delay Box, Nitrous controllers, RPM switches, Throttle controllers, etc" stuff out there at the track. I used to work for him 7 years ago. Cool stuff.
Back on topic - Modifying the placement of parts on a PCB will cause some major headaches.
Even removing it from it's cradle can cause issues. To be consistant, you need to keep it right where GM had it and always make sure your grounds are TIGHT.
As was said, it has been tried, but not much success has been found yet. Sometimes wrapping the cable in aluminum foil helps to cut down on RF, but it is still a crap shoot. FWIW my ECM has been sitting on my floor for probably 2 years now.
I tried it at one time and it didn't work. Best money i spent was on an Ostrich, which allows you to do a similar thing, and gives the added benefit of real time tuning!
An Ostrich - is that the Moates thing? I've seen mention of the name, but wasn't familiar with what it does. Trying to do this without sinking a lot of cash...
I'd thought about wrapping the cable in tin-foil, or also using a flat/twisted pair cable (i've seen them, every pair is braided together but is still fastened to the set next to it).
Maybe what I need to do is just find a better temporary mounting point for the whole ECM.
Jabez, FWIW, the ECM on my early 86 normally belongs behind the dash on the passenger side. It requires some minor contortions to install/remove.
[RICHR]
have you considered making an extension harness for the ecm and relocating it? This would work better.
That's probably what I'm going to wind up doing. $175 is too rich for me right now. Only problem with moving the whole ECM is mounting the heavier item vs just the chip...
So im trying to figure out, does this upgrade your ecm so that you can custom tune it? or does it make the computer like the 91 and later c4's?What is the exact advantage of havning this?
its an eprom emulator.. it plugs into your ecm in place of the eprom. you can then change the tuning in the emulator (ostrich) and its is the same as making changes to the chip EXCEPT you can do it while the engine is running and you don't have to mess around with burning/erasing/removing/replacing pesky chips..
basically the ecm still thinks it has a normal eprom connected.. but its really just a device that emulates an eprom and its contents can be changed far more quickly and easily 'on the fly'..
I tried exactly what you talking about and got to work moderately with aluminum foil around EVERYTHING. But who wants that?
I finally got a Romulator which worked very well and allows you to realtime tuning. Much much quicker than the standard way.
I have the romulator and was going to put it up for sale, but it keeps slipping my mind. I really don't need it anymore since I am toying with DFI to learn that side of tuning.
Let me know if you would be interested. I am going to be selling it.
does that make sense??
thats awsome! thats what i was hoping they would make or already have! what is that like 300 bucks? damn thats cool.
I'd be interested, depending on price. Is this the Hondata device? I'm beginning to think I'm going to need something real-time so I don't have to keep mailing chips off...
Craigs got somethign called a autoprom too that is a emulator, a datalogging interface and a chipburner all in one.. You might want to check with him to see if he still carries them as I know he was gooing to give them up soon.
