Problem with windows
Old Jun 17, 2005 | 10:45 AM
jay17's Avatar
jay17
Default Problem with windows
The window on the drivers side is not rolling down anymore. Anyone what to do?
Thanks for the info
Old Jun 17, 2005 | 10:50 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the motor is running you need to replace the regulator, if it is not running check out the electricals, starting with the switch.
Old Jun 17, 2005 | 11:33 AM
jay17's Avatar
jay17
Is there a fuse?
Old Jun 17, 2005 | 04:06 PM
VMAX451's Avatar
VMAX451
Originally Posted by jay17
Is there a fuse?
There is a fuse, but I think it's its in the auxiliary fuse panel under the dash in the passenger footwell. It's the same fuse for both windows, so if one works and the other doesn't, the fuse is not the problem.
It's most likely going to be either the motor, switch, or regulator.
To Problem with windows
