check eng, code 24
Old Jun 17, 2005 | 05:03 PM
tigmaned's Avatar
tigmaned
Default check eng, code 24
got a new code today 24? VSS from what the book said. would driving with out the digital dash hooked up run that code? were is the VSS?
Old Jun 17, 2005 | 07:49 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Your book should be able to tell you alot more than its the VSS.
Vehicle Speed Sensor, it's in the tail of the tranny. Not sure if the dash out would throw the code but the info from my manual does tell you what to check
http://members.shaw.ca/corvette86/Code%2024.pdf
Is this the same as yours
Old Jun 18, 2005 | 10:12 AM
tigmaned's Avatar
tigmaned
yeah my book is the same i'll have to do some reading about it.
Old Jun 18, 2005 | 10:52 AM
C4Ownr24's Avatar
C4Ownr24
driving without the digital dash sets that code. The instrument cluster provides the ground for the VSS, if I remember correctly. I drove for 2 weeks w/out the cluster and it would intermittently set that code.
Old Jun 18, 2005 | 10:58 AM
tigmaned's Avatar
tigmaned
cool, good to know so i am not going to worry about it till my dash cluster gets back?
To check eng, code 24
