Running Hot (help) ?????
Old Jun 17, 2005 | 11:06 PM
wirenut3's Avatar
wirenut3
Default Running Hot (help) ?????
We have a 1986 vett it seems to me its running hot ?? to day in traffic the temp was runninig 240-248 is this normal or sould I be looking into somthing Thanks
Old Jun 17, 2005 | 11:07 PM
AZC4Guy's Avatar
AZC4Guy
I live in AZ and have an 86... it never gets that hot. Something is amiss.
Old Jun 17, 2005 | 11:13 PM
jfb's Avatar
jfb
Most likely your radiator has debris in it which reduces the airflow and it ability to cool. One fast thing you can do is to hold the fan blade and blast water from a garden hose backwards through the radiator. If that helps, a much better cleaning should be done by taking the radiator shroud off and vacuuming and picking the debris out of the front of the radiator. Normally in summer weather a stock 86 in under 35 mph speeds or at stoplights will go to 238 F and the main fan will come on. When you get underway (35 mph or higher sustained), the coolant should drop to the opening temperature of the thermostat. The stock stat is 195 F. GM says to shut the engine off at 260 F and let it cool down.
Old Jun 17, 2005 | 11:20 PM
Togo's Avatar
Togo
advice doesn't get much better than that!
check this thread to see what EXACTLY he is talking about, about the debris
http://forums.corvetteforum.com/show...65&forum_id=48
Old Jun 17, 2005 | 11:22 PM
JETSET's Avatar
JETSET
Default fan
is the fan going on
you can check it by putting on th AC
it should kick in
if not check the relay
Old Jun 17, 2005 | 11:27 PM
_twisted_'s Avatar
_twisted_
if yours has an aux fan it should be runnning at that temp also, you can check that by grounding the lead going to the sensor located between 1 & 3 cyl squeeze it to get it off and stick your probe in there and ground the other end of the test light.
Old Jun 17, 2005 | 11:38 PM
AZC4Guy's Avatar
AZC4Guy
Hmm. My fan comes on at 225
Old Jun 17, 2005 | 11:39 PM
wirenut3's Avatar
wirenut3
Thanks for all the info I will remove the rad and clean it I was just telling my wife that I dont recall the fan comming on I will check this in the morning thanks alot for all your help
Old Jun 17, 2005 | 11:42 PM
vader86's Avatar
vader86
The main fan comes on at 228, the aux fan in front of the radiator at 238F.
More than likely you have road debris stuck between the condensor and radiator. You'll have to remove the shroud to get it out, and you MUST do it this way, no halfazz spraying from underneath because it wont get it all.
You should also flush out the old coolant, be sure to put green coolant back in, and replace the thermostat. You may go down to a 180 thermo, since you live in Iowa I wouldnt go with a 160 thermo.
Old Jun 25, 2005 | 11:07 AM
wirenut3's Avatar
wirenut3
I found relay it must be bad so I jumped the wires the fan took right OFF Thanks for all your help
To Running Hot (help) ?????
