Overheating Problem
Old Jun 18, 2005 | 09:31 PM
95Torch's Avatar
95Torch
Default Overheating Problem
My 95 has been overheating. At first I thought it might be the water pump, however It it does not appear to be leaking any coolant. If I drive more than a couple of miles the temperature maxes out and the overflow tank is gushing out coolant. I replaced the thermostat, thinking that it might be sticking, but no luck..it still does the same thing. Any other thoughts?
Old Jun 18, 2005 | 10:33 PM
Morley's Avatar
Morley
Is the overflow tank bubbling? Try starting the car and let it idle until it warms up. Then look at the overflow tank, if there are lots of air bubbles pumping into it you probably have a blown head gasket.
Old Jun 18, 2005 | 11:25 PM
okies93's Avatar
okies93
St. Jude Donor 06
also make sure radiator and condensor are clean. plugged up cores can cause all kinds of problems.
Old Jun 20, 2005 | 09:39 PM
95Torch's Avatar
95Torch
If it were a head gasket, then wouldn't coolant be getting into the oil? Also, could it still be the water pump has stopped even though it is not leaking? How can I check to see if is the water pump?
Old Jun 21, 2005 | 03:57 PM
woody1243's Avatar
woody1243
Start up the car after removing the radiator cap. Bring the car to operating temp- when the thermostat opens you should see a flow of coolant in the radiator.
Old Jun 22, 2005 | 02:57 AM
Morley's Avatar
Morley
No, if the head gasket is blown it won't always let coolant into the oil. I had a set fail and just bled cylinder pressure into the coolant system and blew coolant out of the overflow and caused overheating.
One way to check is to remove the thermostat and put the water neck back on, open the radiator cap and start tha car. If you see coolant circulating through the radiator, the pump is working (some at least).
Old Jun 22, 2005 | 10:13 AM
tjwong's Avatar
tjwong
Are your electric fans coming on? Also did you bleen any air out of the system? There is a bleeder valve on top of the thermostat housing. When you refill the system, very carefully open the bleeder to bleed any air out of the system. Be careful about dribbling coolant down onto the Opti. I usually wrap some rags around that area when I do this. If there is air trapped in the system it may cause it to be air locked and then it can over heat because of coolant flow problems.
Old Jul 4, 2005 | 04:18 PM
smar's Avatar
smar
On mine I had a mat of poplar fluff built on the surface of radiator behind condenser which caused overheating.
Old Jul 18, 2005 | 06:14 PM
Green Dragon's Avatar
Green Dragon
4th Gear
I find you look for the simplest solution first. The cap may not be holding the pressure. Have the cap checked first.
Old Jul 24, 2005 | 06:52 PM
blacklight's Avatar
blacklight
Default c-4 overheating
I support Green dragon suggestion. At top of Eisenhower Tunnel in 50th Reunion caravan, one of our cars, a ZR-1 overheated. Going downhill on the otherside it overheated. Problem? Radiator cap was not holding presssure. Rekplaced it. Drove the rest of the 2000 miles without a problem.
To Overheating Problem
