There goes my LCD Cluster..
Old Jun 20, 2005 | 10:29 AM
MrNuke's Avatar
MrNuke
Default There goes my LCD Cluster..
, so my LCD went freaky, then dark on Saturday, and blew it's fuse.
It then blew 3 other fuses right after putting them in the socket..
Then I took it apart and I smelled the slight hint of burned electronics from the powersupply.. Ohh Joy..
Soanyways. what good places, other than than Taber guy are good in rebuilding these and quickly?
Thanks..
Old Jun 20, 2005 | 01:14 PM
chucks88's Avatar
chucks88
I fixed a toaster once
Old Jun 20, 2005 | 01:40 PM
chucksredvette's Avatar
chucksredvette
Here is a place I had mine repaired for alot less than Taber....
Corvette Parts Service and Sales
708 Cory Lane #76
Bloomington, Indiana 47403
Toll Free (888) 454-1911
I called and he sent me a box to ship it in and did the reburb and replace the Speedo LCD for about $350.
Old Jun 20, 2005 | 02:00 PM
MrNuke's Avatar
MrNuke
708 Cory Lane #76
Umm... dude.. That IS Gene Taber....
Old Jun 20, 2005 | 05:20 PM
MrNuke's Avatar
MrNuke
ttt
Old Jun 20, 2005 | 05:41 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The power supply board piggybacks to the top board. I have a spare that you can try. You cover the shipping. PM me if this is reasonable.
Old Jun 20, 2005 | 07:11 PM
MrNuke's Avatar
MrNuke
I opened the cluster up, and this is the only thing I saw that looked out of the ordinary on the powersupply, where I smelled the burning.
I tried to find that piece on-line.. No luck..
Anyone ever fix their own LCD dash power supply?
Old Jun 20, 2005 | 07:31 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Old Jun 20, 2005 | 07:33 PM
eptaylor's Avatar
eptaylor
Default Fix Power Supply?
On the device with the metal tab/back, is there a number on it such as 7812 or 78xx? If not is there ANY number on it? If it is a 7812 or 78xx it is a 3 terminal voltage regulator chip available at Radio Shack, etc. The last 2 digits are the voltage of the chip. Otherwise it might be a transistor. Any more info?
Old Jun 20, 2005 | 09:01 PM
rwsduc's Avatar
rwsduc
How long did it take you to pull the LCD module? I've been traveling a lot lately and haven't had a chance to chase down the gremlin that makes mine blank out intermittently.
As for the component that you circled, have you tried searching Mouser.com or Newark.com for a replacement? Might be worth a shot. Good luck!
Old Jun 20, 2005 | 09:09 PM
tigmaned's Avatar
tigmaned
yeah i sent my dash to gene taber too. i didn't see any burnt parts on mine thought??
Old Jun 20, 2005 | 09:37 PM
montie98's Avatar
montie98
You can try Corvette Center in Newington. They fixed mine years ago so I cant remember what it was.
Old Jun 20, 2005 | 11:17 PM
MrNuke's Avatar
MrNuke
The only other '#' is the imprinted '3H32' on the metal heatsink part.
I couldn't find anything out about it, don't even know what part it really is.. I was hoping it was a regulator or something , but no clue..
I'll call the corvette people in newington to see if they still repair them.. Thanks for the info.
Old Jun 20, 2005 | 11:28 PM
MrNuke's Avatar
MrNuke
It takes me about 5 minutes to take it out..
I checked those sites. Nothing with the exact same referenace or anything..
Old Jun 21, 2005 | 01:29 AM
Corvette0096's Avatar
Corvette0096
Gabe Get a hold of Tjwong.. He will help you out.. He knows that kind of stuff to.
Old Jun 21, 2005 | 11:26 AM
VenkmanP's Avatar
VenkmanP
I poked around a little and couldn't find anything useful on those numbers either.
There's a good chance it took out other things when it died anyway, so I'd be inclined to get it repaired or buy a used one.
Old Jun 21, 2005 | 05:37 PM
MrNuke's Avatar
MrNuke
yeah i Already ordered a replacement one with Corvette Center here in Newington, CT. Was $300 and same day exchange. Should be here thursday. I recently put in a new Stereo headunit, so I'm wondering if that
could be doing something , or it's just a coincidence. The stero's been in th ecar almost 2 weeks, no problems, nad it works flawlessly..
Old Jun 22, 2005 | 01:56 AM
JrRifleCoach
Might try looking for pinched wires behind your stereo installation. All it takes is one wire and they're tough to troubleshoot.
Old Jun 22, 2005 | 09:00 AM
MrNuke's Avatar
MrNuke
Yeah that's what I was thinking too.. Just thought it would blow a fuse on that specific circuit then, instead of the LCD , but the circuits on the early C4's use multiple circuits for power themselves, so it's a mess when you look at the whole picture. Before putting the new LCD in, I'll remove all the stereo wiring and redo it.
To There goes my LCD Cluster..
