A/C coming thru defrost - the final answer.
Old Jun 20, 2005 | 02:22 PM
sremenap's Avatar
sremenap
Default A/C coming thru defrost - the final answer.
91 L98 convertible vette.
I have researched through this site the many fragmented topics of air box control failure resulting in AC coming from defrost. I have a couple questions.
#1 - the vaccum line that connects to the harness on the firewall behind the distributor has been broken off. Is this indeed the feed for vaccum for the manifold to control the air box?
#2 - is there a manual way to lock the blend air door in the air box to always come from the vents? I live in AZ, and defrost really isnt ever a problem for me. I would like a quick fix until i can get the harness replaced if it is indeed the issue.
Thanks.
Old Jun 20, 2005 | 06:45 PM
SunCr's Avatar
SunCr
What you describe should be the vacuum line to the a/c programmer (electronic air) or dash controls (manual air). To prevent performance problems, I'd plug it up. Otherwise, patch it with some rubber line that's close and your a/c will probably work normally. If you want to fix the door positions you need to get the top of the dash off to access the defroster box and door - possibly more to access the heater doors which are inside the heater plenum below it. The defroster door is going to be problematic because gravity is keeping it open so it will be up to your own ingenuity has to how to keep it permanently closed.
Old Jun 20, 2005 | 08:35 PM
MaxLean's Avatar
MaxLean
Repair the vacuum feed. These systems are designed to default to defrost position when the system looses vacuum as a saftey measure. Restore the vacuum to the HVAC and all should be fine!
Old Jun 21, 2005 | 01:52 AM
pablocruise's Avatar
pablocruise
If you have the electronic C68 option system, it is.
That tubing is old and brittle by now. You could pull the old stuff completely out and replace with new stuff.
Replacing the vac tubing with new tubing is the quick fix(only fix)
It will probably make your system work normally and give you full control again. "Replacing the harness" would not include the tubing, only wiring from the ECM to the engine, so that's probably not what you want. The vac tube feeds this controller:
It is housed in a black plastic box bolted to the interior firewall next to the steering column.
Old Jun 24, 2005 | 03:04 PM
sremenap's Avatar
sremenap
Well my problem is that the nipple for the vaccuum line seems to have been broken off
Any ideas?
Old Jun 24, 2005 | 04:11 PM
SunCr's Avatar
SunCr
The Discounters usually have an array of vacuum line accessories along with the glue (though I usually just use super glue). I'd take the Programmer off, measure the hole and then go shopping. Should be able to mickey mouse something that works.
Old Jun 24, 2005 | 04:34 PM
_twisted_'s Avatar
_twisted_
I agree, you can find something to fit. If it were me, I would probably buy one of the assortment kits of vac fittings and T's, and just have at it.
good luck
Old Jun 24, 2005 | 07:42 PM
MaxLean's Avatar
MaxLean
Any ideas?
Where is the broken nipple in that pic? If you're refering to the circular item to the left of the wire bundle, that's something else and not related to the vacuum supply to the HVAC.
Old Jun 24, 2005 | 08:04 PM
johnnyevans's Avatar
johnnyevans
89 Paul in Cal and MaxLean have both got it right.
More often than not, you'll find the plastic vac line has broken.
It usueally happens during a distributor or the cap has been changed, or the manifold has been taken off.
Old Jun 24, 2005 | 08:45 PM
sremenap's Avatar
sremenap
uhhh - i was told this was where the vaccuum goes in for the control box. If this is not the place, can someone tell me where to find the vaccuum line that is coming through the firewall?
Old Jun 24, 2005 | 08:58 PM
brookman's Avatar
brookman
It goes into a wire harness.
Old Jun 24, 2005 | 10:07 PM
sremenap's Avatar
sremenap
Is that the wire harness that goes up into the ECM? Can you mark up that image to show me which line i am looking for?
Old Jun 24, 2005 | 11:54 PM
65coop's Avatar
65coop
St. Jude Donor '05
Mine did the same thing after a installing a new intake - turned out to be a vacuum line that connected to the intake was not on - hooked it back up and everything worked fine..
Old Jun 25, 2005 | 04:26 PM
brookman's Avatar
brookman
At the bottom just right of the middle of the picture - see the brown connector? just to the right of it is the vacuum connector. it goes into the wire loom that exits the top of the picture.
Old Jun 25, 2005 | 10:36 PM
johnnyevans
Brookmans got it. That's the vac for the AC doors. Check it and make sure that you didn't break it and that it's not brittle.
Old Jun 26, 2005 | 01:30 PM
sremenap's Avatar
sremenap
yeah - thats what i thought was teh vac line - but where is that wire harness. where does it originate? I cannot tell from the pic, and stared my engine compartment over to try to find it.
Old Jun 26, 2005 | 06:07 PM
johnnyevans
It's between the rear manifold flange, where the distributor goes, and the firewall. This wire bundle contains the wiring going to the dash, the computer and such. Right where the AC box bolts to the firewall. If it's broken all you will see is the stub of the plastic hose sticking out of the bundle.
It's a whole lot easier to get to and to see if you take the distributor out.
To A/C coming thru defrost - the final answer.
