code 43
Old Jun 20, 2005 | 05:30 PM
Moxxi's Avatar
Moxxi
Default code 43
Would having a code 43 make the car idle rough? It drives ok, just idles kinda rough. Just replaced the computer chip and prom a few weeks ago.
Old Jun 21, 2005 | 08:19 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Trouble Code 43 indicates that there may be a malfunction in the Electronic Spark Control (ESC) circuit.
ESC is used to sense spark knock (pinging) and retard the timing to eliminate it. A knock sensor (located at the rear of the engine block) sends signals to an ESC module which then signals the ECM that knocking is being detected.
The ECM will retard the timing by as much as 20 degrees in 1 degree increments. A loss of knock sensor signal or loss of ground at the ESC module will cause the signal at the ECM to remain high. The ECM will act as if no knock is present, and may possibly result in engine damage, if there is detonation.
Loss of the ESC signal to the ECM will cause the ECM to constantly retard the timing to its maximum. This results in sluggish performance and a Code 43.
The conditions for setting this code are:
Engine is running
ESC input signal has been low more than 2.23 seconds
Typical causes for this code include:
1) Open or shorted knock sensor
2) Loose knock sensor
3) Excessive mechanical noise within engine
4) Improper or incorrectly installed PROM or CALPACK in the ECM or defective ECM
5) Intermittent open in the EST line to the ignition module
You can read more about it and other trouble codes here. This is one of my favorite ECM links.
http://www.gnttype.org/maint/malf.html#TOP
