Coil wire replacing dumb question
Old Jun 20, 2005 | 08:30 PM
DougSilver's Avatar
DougSilver
Default Coil wire replacing dumb question
I want to change the coil-to-opti ignition wire in my 95 and was wondering if anyone has a slick trick to grab the end that plugs into the opti. It is really tight for hands and fingers to try and grab the boot, and also seems awkward for spark plug wire pliers. Is there some easy trick to remove and then install this wire?
Thanks.
Old Jun 20, 2005 | 09:02 PM
Gar's Avatar
Gar
The trick to changing wires on cars with the opti is patience and a couple of hours time. If your gonna do the coil wire ya might as well do them all. I replaced mine with MSD's Take off the surpentine belt and tensioner and carefuly feed the wires thru. You have to be careful to place them exactly the way the GM sado-masochists designed and installed them. Make sure you get them all the way on the opti (it's hard to get ANY leverage) Don't pinch the vent tube from the opti when you put the tensioner back on. HAVE FUN! You'll proly need a few beers when yer done! Oh ya and bandaids.
Old Jun 20, 2005 | 09:09 PM
Lone Ranger's Avatar
Lone Ranger
Thanks.
Since I'm discarding the old coil wire anyhow, I just use a pair of needle nose pliers to grab it. Or a pair of long fishing hook pullers (thing you use to get the hook out when the fish has swallowed it).
Old Jun 20, 2005 | 09:15 PM
DougSilver's Avatar
DougSilver
I was thinking of trying a piece of heater hose--slit so I could slide over the boot and then pull the wire out. I appreciate the advice about changing all the wires but first wanted to try the coil wire as I kept finding a powdery green corrosion on the end that plugs into the coil. I replaced the coil the other day and the car runs better (but still misses) so I next want to replace this wire as something seems suspicious, at least with the end that went to the coil.
Old Jun 20, 2005 | 09:22 PM
Lone Ranger
Sometimes it takes some pressure to get the coil wire onto the coil electrode all the way. I know I've had to take and use the upper palm of my hand against the coil wire while countering with my left hand bracing the back of the coil until it would give me a final "CLICK!", but that was with the Moroso Blue Max coil wire.
On the Opti end, you looking for two clicks. Second click indicates it's on and securely engaged.
Old Jun 21, 2005 | 09:03 AM
Tom Piper's Avatar
Tom Piper
I bought a tool (I think it was at Autozone) that has an adjustable tip (the tip looks like a red duck bill) that can be adjusted for different angles made specifically for installing and removing spark plug wires.
The tip is long enough to use to pull on the boot instead of the wire and also to put the pressure on the boot to install it.
Worked for me.
Or, you could buy a Delteq and not use the spark plug wires on the Opti-Spark.
Tom Piper
Old Jun 21, 2005 | 11:25 AM
DougSilver's Avatar
DougSilver
I saw that type of tool at Pep Boys and almost bought it, but it still looked like it might be difficult to get the tool into the congested area around this wire. I began thinking about the Delteq but am not totally convinced that opti is the problem. I suspect (hope) it is something simpler like bad or badly seated wires or tired plugs. Spending $600+ dollars seems expensive just to accomplish a more convenient way to route plug wires (again assuming that the opti is basically okay).
Old Jun 21, 2005 | 11:59 AM
c4cruiser's Avatar
c4cruiser
When I replaced the original wires on my 92 with MSD Heli-Coil's, I had no problem in getting the coil wire off the Opti. It's important to twist the wire at least a 1/4 turn to get it to release. You should hear the click when it turns to where it will release.
When I installed the MSD coil wire, I used a good coating of dielectric grease on the inside of the boot and it went in easily and clicked into place.
Old Jun 21, 2005 | 05:29 PM
pwrful c4's Avatar
pwrful c4
I used plenty bandaids.
Old Jun 21, 2005 | 05:35 PM
DougSilver's Avatar
DougSilver
I get cuts, lacerations, aches, and sprains just thinking about this. 30 years ago this would have been something I had the time and energy to do myself but those days are long gone
Old Jun 22, 2005 | 06:53 AM
Tom Piper's Avatar
Tom Piper
This is the tool:
http://store.yahoo.com/brandsplace/0246-lis51750.html
I used it in that congested area, and it worked for me.
Tom Piper
Old Jun 22, 2005 | 07:19 AM
runner140*'s Avatar
runner140*
Originally Posted by Tom Piper
This is the tool:
Tom Piper
Great idea, I saw something simular at Harbor Freight for about the same price.
To Coil wire replacing dumb question
