1.6 rocker ?
Old Jun 21, 2005 | 05:57 PM
pipe's Avatar
pipe
Default 1.6 rocker ?
Would I be able to change my stock rocker arms to 1.6 rollers without changing valve springs ? The motor is a stock 90 L 98. Do I have to worry about pulling a rocker stud out of the head or breaking a pushrod with this swap? I just want to try and get a little more out of it before going to the good motor. THANKS FOR THE REPLIES Pipe
Old Jun 21, 2005 | 10:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The stock rocker arm studs are 3/8" screw-in so no danger of pulling out.
Our stock #113 heads have factory non-hardened and non-functional guide plates with self aligning rockers.
So I installed non self aligning 1.6:1 ProMagnum RRs with hardened guide plates & pushrods along with 7/16" studs. This path is about the same total cost as going with self aligning RRs.
Also you should install new valve springs and forged keepers. I used the Comp Cams #981 springs shimmed to give about 120lb of seat force.
Since the springs will be out it would be a good time to install new valve seals too. On reassembly, toss the stock tin oil shedders from atop the valve springs to lighten the valve train a little.
You can expect to gain around 15-20chp this mod with a stock cam.
Old Jun 23, 2005 | 06:02 PM
pipe's Avatar
pipe
So I guess just changing out the rockers won't fly without changing the other items?
Old Jun 23, 2005 | 06:42 PM
65Z01's Avatar
65Z01
And you will need to grind down the drip tabs inside the valve covers as well as narrow the bolt towers to clear the Pro Magnum RRs.
It isn't "necessary" to change all those items but I feel it makes sense once you go in there.
Old Jun 23, 2005 | 06:47 PM
JackDidley's Avatar
JackDidley
I put the 1.6 stamped steel roller tips on my 86 and my 87 without changing anything or grinding anything.
Old Jun 23, 2005 | 07:11 PM
Hotred94's Avatar
Hotred94
Just changing the rockers to rollers will not cause any problems. The 1.6 rockers don't really add much lift on a stock system (read that stock cam) so the springs should be fine. However, it does make sense to upgrade the springs at the same time.
Old Jun 23, 2005 | 10:37 PM
BLUE BETTY's Avatar
BLUE BETTY
Old Jun 23, 2005 | 11:23 PM
65Z01's Avatar
65Z01
My stock '88 valve springs only provide 86 lbs at the seat, which may be fine for a 4,800rpm L98, but I now wind to 5,700rpm so I went with Comp Cams springs at 110 lbs and lightened the valve train too.
Of course changing springs complicates the issue but doesn't bump to cost excessively compared with $260 RRs. Now adding Ti retainers at $140 a set will give costing a nice bump.
To 1.6 rocker ?
