The vendor is a CF Supporting Vendor, but I personally don't know a lot about the company.
If you are bidding on the 2 pairs with 2 9.5" wide and 2 11" wide, you will need the 9.5" wheels for the front in 56mm offset and the 11" wheels for the rear in 50mm offset.
Tire sizes for the fronts can be either 275/40-17 or 285/40-17. The rear tires should be 315/35-17. The rears will not hurt the speedo accuracy. They may stick out a bit from the rear wheelwells but not a lot.
I bought from this Manufacturer and TOMZ, got 9.5 all around and 255 up front and 285 in rear, all 17". Great dealing with Tomz and Manufacturer. Only problem was one of the center caps was damaged, called Tomz and had a new one in 4 days.
I bought some black A molds for my 94 that were 9.5 on all 4 corners. I run 255 in front 285 in back but plan to go to 285 all the way around so I can rotate. My vette is lowered and I wanted to go with 9.5 in front 11 in back with 285 / 315 respectively but was afraid to rub.
Has anyone bought from this manufacturer and what do you think?
Any help much appreciated!
That is the vendor I bought mine from and yes he is reputable. One rim was marred and he shipped me up a new one no additional shipping charge, and just swapped the one out w/UPS guy. Id do buisness w/Tom again.
