Engine weight - LT-1 vs LT-4
Old Jun 22, 2005 | 03:36 PM
rmdickson's Avatar
rmdickson
Default Engine weight - LT-1 vs LT-4
I read that the LT-1 engine weighs 785 lbs and the LT-4 weighs 1003 lbs. Is this true and if so, why? They both have cast iron blocks and aluminum heads.
Old Jun 22, 2005 | 03:38 PM
F1Fan's Avatar
F1Fan
That information you read has to be wrong.
Old Jun 22, 2005 | 03:39 PM
dchildress's Avatar
dchildress
How much does an LT-1 engine weigh?
Old Jun 22, 2005 | 03:44 PM
rmdickson's Avatar
rmdickson
The specs are on this web site: http://www.corvetteactioncenter.com/...96/lt1lt4.html
Old Jun 22, 2005 | 05:26 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
The motors are so close. What could possibly account for that much extra weight? It's not like the LT4 has iron heads... What gets me is the weight is listed this way on the CAC link above...
Old Jun 22, 2005 | 05:30 PM
all4c4lt4's Avatar
all4c4lt4
This has been discussed many times before. The info on that site is wrong as to the weight of the engines.
Old Jun 22, 2005 | 05:34 PM
dchildress's Avatar
dchildress
* Note: These numbers are courtesy of GM Powertrain and come from the Mass Group at General Motors. They may not be 100% accurate.
This is from the bottom of the above link. It is almost like somebody weighed it wet with all the accessories attached including bell housing and clutch assy.
Old Jun 22, 2005 | 05:39 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Both those numbers are wrong. An all iron SBC doesn't weigh that much. And there certainly could not be more than the most negligible difference between an LT1 and 4.
Old Jun 23, 2005 | 01:38 AM
VenkmanP's Avatar
VenkmanP
Heck. An all iron BBC doesn't weigh that much.
Old Jun 23, 2005 | 01:41 AM
VenkmanP's Avatar
VenkmanP
Looks like low 500s
http://www.rodandcustommagazine.com/...66/index5.html
Old Jun 23, 2005 | 02:53 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
It's just like a henway.
I think about 2 lbs.
To Engine weight - LT-1 vs LT-4
