Front swaybar differences between years
Old Jun 22, 2005 | 04:44 PM
shotchkiss's Avatar
shotchkiss
Default Front swaybar interchange between years?
Are the front swaybars different between the 85-87 vettes and the 88-96 ones? If so, what is different or how do you tell the differences?
OK, I probably asked the wrong question above. When I've see swaybars listed, they are either for 85-87 or 88-96. Iwant to get a used 30mm front swaybar for my '89 and was wondering if there was any physical difference between the bars used in the earlier cars vs the later ones, or if it is just the mounting hardware that is different.
Last edited by shotchkiss; Jun 22, 2005 at 10:13 PM. Reason: Question Clarification
Old Jun 22, 2005 | 08:03 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Yes, sway bars differed by years and even within years depending on the suspension options
do a google search on hib halverson, look for his web page on c4 suspensions. I used to have it, but I lost it
seeya
Old Jun 22, 2005 | 11:24 PM
rodj's Avatar
rodj
http://www.idavette.net/susp_chart.htm
Old Jun 23, 2005 | 12:01 AM
vader86's Avatar
vader86
They changed the suspension geometry in 88, and generally the sway bar size increases after those years as they changed their suspension philosophy starting in 88.
You will not be able to use the earlier bars in front.
Old Jun 23, 2005 | 08:17 PM
shotchkiss's Avatar
shotchkiss
So how do I tell the later (88+) bars apart from the earlier ones (85-87) if I were to go to a swap meet and look for them? Do they measure different between the mounting points, are they shaped different...?
To Front swaybar differences between years
