While I'm at it... (differential, what else?)
Old Jun 24, 2005 | 12:12 AM
lachrimae's Avatar
lachrimae
Default While I'm at it... (differential, what else?)
My exhaust system is off & the differential is soon to follow. What should I consider upgrading/servicing/replacing while I'm under there? If you can help me create a list I'll go shopping
I don't plan to do anything big like shocks but anything within reason may as well be updated. (Currently @ 72k with '92)
Mark
Old Jun 24, 2005 | 02:07 AM
86PACER's Avatar
86PACER
If it where me I would check the drive shaft and half shaft u-joints as well as the rear suspension bushings.
Old Jun 24, 2005 | 10:11 AM
mash557's Avatar
mash557
Would also be a good time to change rear end lube and oil seals at side and pinion yokes if they are leaking.
To While I'm at it... (differential, what else?)
