Not just another "cooling" thread
Old Jun 25, 2005 | 02:01 PM
Ramanstud's Avatar
Ramanstud
Default Not just another "cooling" thread
The radiator is OEM replacement aluminum, clean, 2 yrs old. Brand new edelbrock "high flow" pump with operating main fan which is also less than 2 yrs old. Just replaced coolant, near a 70-80% mix for Ohio seasons.
Car likes to get hot at idle. When moving it will stay at or below ~200* F. But idling it will creep over 240* and up (ambient temps 85-95* F)! I'm running a superram'd 383, LPE 219 cam with 19* advance at idle and appropriate fuel mixutures per the ECM and no glowing exhaust manifolds. No A/C or condenser in the way, outside of the radiator I just have a stand-alone tranny cooler.
So, have I maxed out the cooling efficiency of the OEM radiator and fan assembly? 84's only have one main fan and it runs 100% of the time when under 20 miles an hour or so and I have yet to see it plateau on idle coolant temps... I have to shut it down at 240*-ish for my own sake.
Outside of adjusting the coolant mixure to more water than antifreeze, should I justify to myself a bigger aluminum aftermarket radiator and/or a high-end CFM fan? I have yet to see a ballpark on the CFM of the stock fans in the archives, so I don't know what ballpart I need to shoot for.
Advice?
Old Jun 25, 2005 | 04:42 PM
CFI-EFI's Avatar
CFI-EFI
That is too much coolant for the lower 48 states. A 50/50 mixture will protect against freezing down to -34* F. Pure water absorbs heat better than antifreeze. Weaker water/antifreeze mixtures do as well. Has the area between the condenser and radiator been cleaned out? My cooling system is all stock except for the fan switch. Sitting and idling, my fan come on at 205-207*. It gains 1 or 2 degrees after the fan comes on, then the temp drops, until the fan goes off at 195-197*. It keeps doing that as long as the car is standing still. Once I get moving the water temp drops to ~185*. I have a 180* thermostat.
RACE ON!!!
Old Jun 25, 2005 | 07:03 PM
Ramanstud's Avatar
Ramanstud
Yeah the radiator is clean and the ousides cleaned of debri...
I've searched the archives enough to pick up on that one and on the ideal mix of antifreeze. the two variables I'm unsure of are:
How big of a temp difference 50/50 versus 30/70 would make, and what CFM the oem fans can pull. So although I'll adjust the coolant mix for more heat disappation, I would think that a motor should be able to idle without burning itself up! haha.
Anybody with a SR / 219 cam have heat issues with OEM cooling components?
Old Jun 25, 2005 | 07:30 PM
TIMSPEED's Avatar
TIMSPEED
you DO know that the stock fan is programmed to come on at like 228º, right?
Old Jun 25, 2005 | 07:34 PM
CFI-EFI's Avatar
CFI-EFI
The difference in freeze protection should be on the outside of the antifreeze bottle. The best for heat transfer is 100/0. Regardless of the concentration of antifreeze, Water Wetter DOES help.
I agree the engine ought to be able to sit and idle. Is your fuel mixture lean? Timing retarded? Sorry, I have never seen a cfm rating on the stock fans.
RACE ON!!!
Old Jun 25, 2005 | 11:30 PM
zr1-2go's Avatar
zr1-2go
Consider the idle RPM. A slow idle may not move enough liquid through the radiator to provide cooling. You might bump up the idle a couple hundred RPM.
Old Jun 26, 2005 | 01:15 AM
-js-'s Avatar
-js-
What shape is the a/c condensor in ?
Mine had a bunch of bent/closed fin areas that prevented the air to get to the radiator.
AC worked fine but it ran hot.
My bad missed that the condensor was out.
Old Jun 26, 2005 | 02:06 AM
jfb's Avatar
jfb
Read the beginning of his post. He doesn't have an a/c condenser, only the radiator.
From cold, open the radiator cap and let it idle until you get to the opening temp of the thermostat. Then you will be able to see if you have reasonable coolant flow. Low flow, low ability to cool your engine. I have a stock 87 except for a Stewart water pump and at idle in the summer, the coolant goes to 200 F (195 stat) and quickly cools down to 195-198 when I get underway (50% antifreeze). Your cam could be causing more heat at idle and I recommend 50% or lower antifreeze and if the above test shows low coolant flow, up the idle speed.
Old Jun 26, 2005 | 01:10 PM
Ramanstud's Avatar
Ramanstud
a couple of details:
I'm using an aftermarket fan relay that causes the single fan to come on around 210* F from the cylinder head sensor. As previously stated, no A/C condendsor and since I removed the engine to do the cam install and other things, the rad was removed, cleaned and debri removed from the shroud.
I did dilute the coolant some yesterday but I have yet to check the actual mixture ratio so the word is still out on that. Also, I'm uing a 180* T-stat that appears to be functioning properly. THe engine drives well and seems to be running properly at idle via Datamaster scans - the O2 voltage is on target with total timing in the 19* range.
I'll check the T-stat operating range to verify an increase in coolant flow at the opening temp - but given the engine's ability to cool while moving and essentially all other conditions other than idle it doesn't make sense that the thermo would be stuck closed or signifigantly reduce cooling power. I think at this point my main problems are either going to be the coolant mixture or maxing out of the stock fan at idle.
I'll post what I find...
Old Jun 26, 2005 | 01:48 PM
CFI-EFI's Avatar
CFI-EFI
I think the water/antifreeze concentration can make a little difference, but I expect it will be subtle, at best. I think the best clue is in this quote.
Nineteen degrees, total timing is a good 15*, if not more, retarded from the ideal total required to make power. And that is ASSUMING you mean total in the sense of the old time max advance (all mechanical) at WOT. If that was a steady state observation made with a scanner, then it is even worse, because the 19* observed ,would include what would be considered vacuum advance with a mechanical distributor. If you wrote it correctly, and I understand it correctly, I think you have serious timing issues.
RACE ON!!!
Old Jun 26, 2005 | 08:19 PM
Ramanstud's Avatar
Ramanstud
RACE ON!!!
19* timing is simply what I'm running AT idle (realtime) with no load and not moving from 800-950 RPM (commanded idle speed). Obivously, if the engine is under load, moving and at different RPM then the timging will change. My understanding is that this is close to the OEM prom settings - but I could be wrong?
Are you running a drastically different advance at idle or did you think I was saying the total timing the engine ever sees under any circumstance is 19* advanced?
Old Jun 26, 2005 | 09:06 PM
CFI-EFI's Avatar
CFI-EFI
I thought you said, "THe engine drives well and seems to be running properly at idle via Datamaster scans - the O2 voltage is on target with total timing in the 19* range.". I can only go by what you post. If I read that wrong, I apologize. *I* equate the term "total timing" with the old, maximum centrifugal advance, at WOT, as used yesteryear. Others have inquired about "total timing in THAT context.
RACE ON!!!
Old Jun 26, 2005 | 09:14 PM
Ramanstud's Avatar
Ramanstud
sorry! I meant "total timing AT idle was 19*"
However, I pulled the exhaust today to drop the transmission and I noticed the driver's side of the front Y pipe was chalky white (no "power" or deposits, but paper-white in color on the inside). the passenger's had what I equate to a normal opaque color. SO I may be getting coolant into one of the combustion chambers of #1-7. that may be causing extra heat if it goes both ways, although the coolant itself looks clear green with no bubbles or foam...
Oh well, another lead to chase down.
Old Jun 26, 2005 | 10:02 PM
FD2BLK's Avatar
FD2BLK
The only help I can offer here is the 84 fan wouldn't cut it for the LT1 after I converted the car. I know it is not the same thing but perhaps it will give you some idea of a posible limitation of the fan. I installed a 95 Z28 duel fan assy and it cooled perfect after that. It did require hacking up the stock shroud but it solved my cooling problems for a lot less money then a custom alm. radiator.
Old Jun 26, 2005 | 10:51 PM
Ramanstud's Avatar
Ramanstud
thanks for the above post. There's virtually no information on CFM per HP requirements in the archives - so your post helps me think that the OEM 84 fan may not (even in it's prime) be able to effectively deal with the heat from a modded stroker motor relative to the output from the stock crossfire....
Can you email me a pic of the mods you did to your fan shroud, and the part # of your fan?
Old Jun 26, 2005 | 11:32 PM
FD2BLK's Avatar
FD2BLK
Send me your e-mail address to ejfagal@yahoo.com and i will send the only to pics I have left of it mouted. The 84 reached a tragic end about two uears ago.
Here she is at her best
Somthing I would rather forget
Old Jun 27, 2005 | 01:31 AM
Ramanstud's Avatar
Ramanstud
I saw that on your webpage (linked from sig). At least you're around to drive another one....
Oh, and your email address bounced - so feel free to email me at jesjhami@indiana.edu
To Not just another "cooling" thread
