abs light comes on
Old Jun 26, 2005 | 02:02 PM
smokey 1's Avatar
smokey 1
2nd Gear
Default abs light comes on
i have changed the brake bias spring that mid america sells to improve front to rear bracking balance did everthing that instructions says brakes work very good but know when taking corner and bracking my anti brack light comes on in center dash and stays on tell i shut car off brakes still work good has enyone had this problem. have never had any problems till i changed this spring how can i bypass the abs so the anti brake light doesnt come on. thanks
Old Jun 26, 2005 | 04:36 PM
tigmaned's Avatar
tigmaned
that is funny about a spring. but do you still hear your pump coming on when you turn the key to on?
Old Jun 26, 2005 | 05:57 PM
smokey 1's Avatar
smokey 1
2nd Gear
yes pump turns on when i hit 4mph . everything seams to be working tell ihit brakes in a corner then the lite comes on and abs doesnt work after that.this is on a 89. mybe put old spring back in see what happens just wonder if any budy else has changed this spring and had this problem thanks
To abs light comes on
