Part number for the Spicer U-joints in the 1/2 shaft?
I am in search of some u-joints that don't have the needle bearings since mine are self destructing on the first launch lately.
In the meantime I am going to put a set of my old ones in, and have them cryoed at Dads place. Hopefully they will live for a short period of time, and then I can try the needless ones if I can locate some.
Jesse,
The ujoints coated for aluminum is 5-800x
Since you do not keep the ujoints on the car for years at a time, you can buy the 5-799x for less than $20 at any spicer/truck distributor. These are there HD model #'s.
You probably will have to order 5-800x. Just go with 5-799x - same ujoint, it does not have the aluminum friedly material on it.
You do not keep the ujoints on long enough to worry about it.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by ralph
Good = 5-800x
Gooder = SPL30-2X
Please explain. Are these the same ujoint just different part numbers or is one supposed to be stronger than the other?
Supposedly they're stronger. I don't have anything to back it up, and haven't compared them side by side. The SPL's also have the coated caps. I took some pics of them next to the stock spicers. I haven't gotten around to posting em. I dunno if the differences are materials or dimensions or what.
I guess I lucked out, I bought them from Gary (formerly Tom's diff) and got the whole set of 6 for $150 or so, he had em in stock.
