Will the NX LT1 Kit work on my L98?
The Barry Grant website shows that they ARE different kits, but the plate should work with my L98 system, correct? Minor differences might be throttle activation bracket, I assume...but the bottom line is, will it work?
A barry grant LT1 kit will not work on an L98.
The runnners or what ever they are called will not allow the plate to bolt up.
I had to switch to the NX universal kit.
Here's the NitrousWorks kit...
Here's the NOS kit...
The PLATES look the same...
Originally Posted by TIMSPEED
That makes absolutely no sense...
I have used the BG system on two LT1 F bodys. It does fit but on one car that had a BBK TB the plate was too thick and I had to grind clearance notches in the Thermostat housing. Using a Arizona Speed and Marine 58mm TB had no clearance issues. I remote mounted the solenoids off by the shock towers and used longer hoses to connect to the plate. Other than that the BG plate system works fine on a LT1 F body and I would suspect a Y body as well. Also the BG plate is machined for 48mm bores, I had the plate machined to 58mm at a local machine shop. The NOS kit uses a plate that is bored to 58mm but its too thick!
Originally Posted by tjwong
I have used the BG system on two LT1 F bodys. It does fit but on one car that had a BBK TB the plate was too thick and I had to grind clearance notches in the Thermostat housing. Other than that the BG plate system works fine on a LT1 F body and I would suspect a Y body as well.
It will work fine.
FACT !!!! AN LT1 BARRY GRANT NITROUS PLATE WILL NOT FIT AN L98.
SkateparkDave has the L98 kit ,I used the BG on my LT1 and the NX on my L98.
Caps lock works wonders friend.
YES! Go ahead and try it, you will have a great time tring to change your jets on the plate.
